Thread: too much combined chlorine
    Hey, i've owned pools for awhile but am new to this forum and I like the idea of saving $$ the BBB way. My chlorine levels are way out of whack--combined is 4 and free is 0--and I'd like to know how much bleach (6%) to add to get the combined down to 0. I have an above ground pool with a capacity of 8,000 gallons. Also, how long will my children need to wait before they can swim again after I add bleach.
    Thanks for any help you can give.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Hi,
    read these "stickies"
    http://www.troublefreepool.com/sticky.php
    and find out what your shock level is based on your pool, using the pool calcs and best guess charts....
    Definetly bring it to shock level and then you should be able to swim when your FC level drops back down to 5-10pmm....
    11,969
    Also, I would highly recommend posting your equipment list, and also a complete set of test results, like FC, PH, TA, CYA, etc. if you don't have a good test kit, that should be the first thing you spend money on, the second being bleach!!!
    Good luck! Welcome to TFP...
    Thanks. I have a ProLine DE filter and 1hp pump. The rest of my tests are all fine--pH 7.4 TA 100 CYA 40. My only problem is getting rid of the combined chlorine. Thanks for the info.
    11,969
    Your welcome.
    The pool calculater says for 8,000 with your CYA that you should have a shock level of 16ppm so you should add
    "2 gallons 1 cup 1 oz or 2.8 (96 oz) jugs" of bleach to reach that level.
    Good luck!!!
    The pool calculator is just pure magic. We are all so blessed to have this forum...
