Thread: Two weeks wait to swim after fill or wait more?
    Azmp1's Avatar
    Jul 2012
    Maryland
    283
    My builder told me two weeks after fill which will be in two days. Though I'm still a bit concerned as I'm reading some info suggesting a full 4 week wait.
    We did a normal start up with only sequestering agent being added. The chemistry is now in good order, pH still goes up everyday but I'm keeping it at bay with MA at ~7.6. Everything else is within normal levels now. So are we good to go to start using the pool at the two weeks mark?
    19200gl rectangular gunite/diamondbrite perl pool || Coverpools auto cover || Jandy variable speed 2hp e-pump & Polaris PB4-60 booster pump || Polaris 3900 sport cleaner || Jandy CV filter || Jandy AqualinkRS8 w/Aqualink touch || Jandy iAqualink2.0 || Jandy Watercolors LED || Jandy AquaPure 1400 SWCG || Hayward auto chlorinator (backup) || Raypak 117k BTU heat pump
    Re: Two weeks wait to swim after fill or wait more?
    There are two concerns. First, in the first several hours it is possible to damage the plaster. After than, you don't want to swim until the PH is under control and the pool has measurable FC levels. That often takes a week or so. Some are more conservative, but once PH and FC are in appropriate ranges I don't see the point of waiting longer.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,817
    +1. We swam at 9 days after plaster, 7 days after equipment. That's when pH and FC were correct. Enjoy, hot weather is here.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Azmp1's Avatar
    Jul 2012
    Maryland
    283
    Thanks guys. The chemistry looks good and the plaster dust is just about gone. Yes going in today. Pool is 85
