Thread: Cloudy Pool
    Cloudy Pool
    vinyl Liner
    27000 in ground
    Sand Filter
    FC - 12, yes taking it to 15 according to what the pool calculator told me.
    TA 50
    CYA 30 to 40
    PH 7.4
    Pool has been cloudy for a while, slight green tint to it
    Been brushing it each day
    Just vacuumed to waste and am filling it back up as I type this
    Been using Walmart Bleach
    Added some cellouse DE substitute to filter
    What else can I do?
    Rain has been real heavy in our area and caused the pool to fill up
    Thanks
    27,000 in ground vinyl liner.
    BBB Method being used
    Sand Filter
    Located in Rochester NY
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    Re: Cloudy Pool
    Filter/pump 24/7 and see if it clears.
    Re: Cloudy Pool
    It can easily take a sand filter a week to fully clear up the water after an algae outbreak, counting from when the algae is all dead. If everything is going well, you should see a visible improvement from day to day, maybe not large, but something.
    Re: Cloudy Pool
    ok
    Green cleared up fast after chlorine level was kept at 15 for a day or so.
    Water is starting to clear after running pump over night.
    Needed to backwash this afternoon after we got a bunch of rain and the pool got close to the top of the skimmer opening.
    So we will keep it running 24/7
    Thanks
    Sand Filter
