Thread: Skimmer/jet water flow question
    Aug 2011
    Northville, Mi
    312
    I'm struggling with how best to have my jets and skimmer to get maximum skimming from the pool. I have a wide mouth skimmer (which seems to do little else besides reduce the pull of the skimmer itself, since the actual weir/opening is much smaller than the mouth) which doesn't work all that great. The skimmer and the current position of a skim-it are the yellow items in the pic. The orange box is my stairs and the two white boxes with arrows are the jets and the direction they are pointed currently. The one in the upper right is the kind of jet that goes along the wall, while the other is just a straight jet (slight angle, but straight, for all intents and purposes). The wind usually comes from the west (left to right across the pool).
    So...the question is...what kind of jets would you have and how would you aim them and how would you put the skim-it in order to maximize the skimming that happens?
    [attachment=0:2fgzl0d1]water flow.jpg[/attachment:2fgzl0d1]
    15,400 gal, 16x32 vinyl rectangle (sport dig), Intelliflo VS, 240 sqft cartridge filter, Intellichlor IC40, Mastertemp 250, Dolphin supreme M4 cleaning, Pentair EasyTouch4, Tested regularly and accurately with supplies from tftestkits
    Jul 2010
    Philly
    332
    Re: Skimmer/jet water flow question
    Looks good your way. Maybe treat each jet like a bank shot to the skimmer in billiards and angle each one that way. Someone here had a great suggestion of using a ping pong ball to see how it reacts to the wind and flow. I have used a bleach bottle cap but I don't think that reflects the winds' effect as much as the ping pong ball.
    Bill
    18'X4' 7600 Gal AG
    3/4 HP Pentair Pump
    Hayward S166T 100 lb sand filter
