Thread: Newbie question about FC in a SWG pool
    Jun 2013
    Bucks County PA
    94
    Happy Fourth of July! I was hoping for some confirmation that the pool is ok to swim in today.... I am new at this, have been reading Pool School and have started testing using a Taylor 2006. We did not use the pool in about 5 days due to rainy weather.
    Here are the results of the tests from 5 days ago and today:
    Test 5 days ago Today
    FC 7.5 12
    PH 7 7
    TA 90 90
    CH 170 150
    CYA 95 90 - 95 (went down a little bit)
    I checked out the Chlorine/CYA chart in Pool School and the chart does not go up high enough to account for a 90 - 95 CYA
    My FC is much higher at 12 today - Is it ok to swim in? Is my Ph too low?
    The solar cover was on for 5 days, I took it off this morning before I tested but it is not that sunny today.
    Any thoughts?
    22Kgal (18x36 3.5-6ft), IG,Vinyl,DE 36sqft Filter -90GPM flow rate, Pentair Whisperflow Pump,SWG Intelichlor, UltraTemp Heat Pump, New 10/2012 Bucks County PA
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Re: Newbie question about FC in a SWG pool
    Yes, that's below shock level, so it's safe to swim. When you have the pool covered, you don't lose any FC to sunlight, so you can turn down the SWG.
    Feb 2012
    Cypress, TX
    131
    And get that ph up a bit to around 7.4-7.6.
    23x40 freeform w/spa, 28,000 gal. PCC-2000 in-floor cleaning. Pebble Sheen w/flagstone coping. 14' weeping wall, (2) 18" sheer descents. Sta Rite- cart 400 sqft. filter, Intellipro VS pump, 1hp (cleaning)2hp (water feature)Max E Pro's. Easy Touch 8 function w/IPod. Rainbow chlorinator, Paramount Clear O3 (I know, I know), Max-E-Therm 400K heater.
    Jun 2013
    Bucks County PA
    94
    Thanks so much! I think I am starting to get the hang of this - I added a box of Borax last night after the fireworks .... and this morning the ph numbers are better. Supposed to be a hot one today in PA - so the pool is up and ready for action.
    FC 10.5
    PH 7.4
    TA 90
    CH 130
    CYA 90 - 95
    I noticed the CH level went down too? Is that a byproduct of the Borax or just a fluke test result? I have a vinyl liner so the CH is not a big concern.
    Thanks again for the help and enjoy the weekend!
    Aug 2010
    Dallas, TX
    4,052
    CH is probably the hardest test to get right. You really have to swirl like crazy. But, once you know where it is, you can ignore it for weeks. At most once a month is plenty to test CH.
