Thread: Algae now in pool
    Algae now in pool
    I just got out of the hospital and have about a 12" band of green algae around the top of the pool from the water line downward. I will have my grandkids come tomorrow, ages 7 and 5. They will be leaving Tuesday. I am concerned about the FC level to kill the algae with them in the pool. The recommended amout is about a FC is 20. Is that too much for the kids to get in the pool? If it is, then can someone give me the guidance to keep the algae in check until the kids go home and I can then work on the algae problem
    These are the measurements this moring
    FC 3 (added cholrine this morning to bring the level up to 13)
    CC 0
    Ph 8.0
    TA 80
    CH 230
    CYA 50.
    Many thanks, lawjohn
    16100 gallon rectangle pool built in 1984 including a 5' X 5'x 3' Spa, Diamond Brite in year 2000, Non-SWG Pool
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,581
    Re: Algae now in pool
    It is safe to swim up to the shock value level for your cya. DO NOT put the kiddos in if you can't see the bottom! Brush off all you can or vacuum it to waste before you start the shocking process. MAINTAIN shock level! Run the filter/pump 24/7 until it clears. See the chlorine/cya chart in pool school for shock value. Lower your PH to mid 7's first. Go buy a BUNCH of Bleach!
    A very big thank you.......- lawjohn
