Results 1 to 19 of 19
Thread: Does my CYA seem a little high?
    Haley's Avatar
    Jun 2013
    Washington
    73
    Hi all,
    So yesterday my numbers seemed quite good and we went swimming last night in our new fill. Afterward I dumped in a cup of bleach and called it a day.
    Yesterday's numbers:
    FC: 5.5
    PH: 7.3
    TA: 140
    CH: 180
    CC:0
    CYA: Didn't test for it because I had just added 24 oz. that morning for the first time
    Today's numbers:
    FC: 6
    PH: 7.4
    TA: 180
    CH: 140
    CYA: 65!
    CC: 0
    What do you think? Also, should I leave our pool cover on when we're not using it? It's a nice, dark heavy one. Thanks for your help!!!
    Intex 15'x48" AG metal frame pool (4,440 gal), Krystal Clear (1600) 14" sand filter, Taylor K2006 test kit, Intex Deluxe Maintenance Kit/vacuum (love it!), Intex Deluxe Skimmer, BBB.
    Feb 2008
    Denton, TX
    5,061
    Re: Does my CYA seem a little high?
    Did you add 24 ounces of CYA by weight or by volume?
    ETA: Meh, really wouldn't make much of a difference whether it was by weight or by volume. 24 oz. should get you really only to 40 +/-. Are you certain about the volume of water in your pool?
    Haley's Avatar
    Jun 2013
    Washington
    73
    By weight I believe. There are 28 oz in my canister of of BioGuard stabilizer (1.75 lb) and I added almost the whole thing into my sock. Did I mess up??
    Haley's Avatar
    Jun 2013
    Washington
    73
    I believe so (about the volume), I'm about where the fill line is supposed to be. Should I dump some of the water?
    Feb 2008
    Denton, TX
    5,061
    Nah. You can always let a little water out and refill.
    28 oz. should raise a 4400 gallon pool's CYA by 48. The CYA test can be +/- 10 depending on the time of day your read it, the ambient light, and where you are when you read it. I'd wait 3 or 4 days and check again. If it is still high, then replace a little water.
    Haley's Avatar
    Jun 2013
    Washington
    73
    Oh thank you for your help! I'll definitely follow your advice.
    Any thoughts on whether or not I should cover our pool during the day when we're not using it?
    alanpaul's Avatar
    Aug 2010
    South Florida
    227
    Haley, as you probably surmised, 24 oz. of dry CYA would raise your 5300 gallon pool's CYA level up by about 34 ppm, according to the Pool Calculator. I suppose 34 was your approximate target, and you assumed a starting point of 0 CYA before adding it.
    So, either you tested incorrectly, and your level is not really 65 (did you double your result in the testing process somehow?), or there already was some CYA in the water. I hope it was your test that was off.
    What were the lighting conditions when viewing? Bright sun behind you. Or very bright indoor lighting?
    How far away from your eyes when viewing? Not too close.
    Now, keep breathing.
    Will some expert post the exact testing method / advice for Haley, please?
    Thanks.
    Alan in Wellington, FL - near West Palm Beach
    15,200 gal IG, painted plaster, 1988; 200 SqFt cartridge filter, 2013; 1.5 HP 1-speed pump (uprated), 2005; heat pump, 2005;
    soon to repair (dead) SWG AquaRite T-15 cell, 2005, and replace (dead) suction-side cleaner, 2005.
    Almost everything died this winter 2012-'13, and I know we shouldn't complain... but, Arrgh!
    Haley's Avatar
    Jun 2013
    Washington
    73
    I eye-balled the holding back of the 4 oz (my container holds 28 oz. I only needed to add 24 oz.) when I poured into my sock. I'll bet that I put a couple extra ounces in.
    Alanpaul, to answer your questions:
    1. You said, "Haley, as you probably surmised, 24 oz. of dry CYA would raise your 5300 gallon pool's CYA level up by about 34 ppm." I only have a 4,440 gallon pool.
    2. Yes, I started with 0 CYA in the pool. It's a brand new fill.
    3. I will definitely retest in a minute.
    4. The light was indoor, not the brightest. I just woke up, but sunlight was present in the room. I'll keep this in mind when I retest. Should I be outdoors? My eyes were about seven inches from the top of the little plastic thing. LOL!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Yes, outdoors sun to your back tube viewed at about arms length
    Haley's Avatar
    Jun 2013
    Washington
    73
    Thank you, Isaac! I just went and opened up both my filter valves to the pool and dumped about 7 inches of water. We all know the CYA is too high and there's no way to get rid of it, and I'm going to have swimmers in the pool later today. So after I'm done filling up those 7 inches I lost, I'll retest. That sound like a plan?
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by Haley
    Well, 24ozs should be about 40CYA. You don't want to wait and retest?
    Here's a link to the Extended Kit Testing Directions......: stand w/back to sun and hold sample at about waist level:
    extended-test-kit-directions-t25081.html
    You're done SLAMing when:
    Haley's Avatar
    Jun 2013
    Washington
    73
    Hi Butterfly, I'm pretty confident that my CYA is around 60-65. (I do believe I added too much.) I figure this way, I can retest after I fill and if I need to add more later, I can. Thank you for the link!
    Haley's Avatar
    Jun 2013
    Washington
    73
    UPDATE
    After replacing those several inches earlier, I waited for a bit, re-tested just now... and sweet perfection: 35. My FC looks great too. So we're good. For now.
    Thanks to all who commented! It helped me out so much!!!!
    alanpaul's Avatar
    Aug 2010
    South Florida
    227
    Haley,
    I posted 5300 gallons based on your posted dimensions and the Pool Calculator's... uh...calculations.
    So...maybe your pool isn't quite 15 feet wide or quite 4 feet deep.
    It says 4400 gallons would be the volume of a 15' round pool with 3' 4" of water, approximately.
    Or are we talking about that 7" of water you lost?
    BTW, where did it get to?
    JK. It really doesn't matter, I suppose.
    And now we're thrilled that your numbers are great!!
    Haley's Avatar
    Jun 2013
    Washington
    73
    Hi Alanpaul! Huh, that's interesting about the pool volume. I'll look into that.
    As for where my 7" went, I posted right after Isaac's post that I went out and dumped about 7" worth of water onto the ground so I could refill with fresh water. Thank goodness it worked!
    alanpaul's Avatar
    Aug 2010
    South Florida
    227
    Haley,
    Sorry, I misunderstood.
    I didn't realize you dumped OUT 7" of water, first.
    I thought you just put IN 7" of water that wasn't there before.
    Duh!?
    Haley's Avatar
    Jun 2013
    Washington
    73
    Ahahaha! No worries! I was all over the place trying to decide what to do. Thanks to all of you I'm sitting outside watching my kids do some night swimming.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    4440 gallons is correct for that pool according to intex.
    Haley's Avatar
    Jun 2013
    Washington
    73
    Aha! Thanks, Linen! That's where I got my number. I am assuming that Intex is calculating only up to my fill line, (around 42") where Pool Calculator is accounting for the full 48" high. Maybe? In any case, I'll keep using my 4,440 gal number. Thanks everyone!
