Thread: Possible "dumb" question?
    Jun 2013
    North Western NC
    12
    I was wondering if our older pool has an issue as there is no drain in the floor? It has a vinyl liner and a single skimmer in the pool wall. The pool came with the house that we purchased and I am used to seeing a drain in the floor of residential pools or do vinyl lined pools normally only have wall skimmers? Hope you are able to have a Happy 4th of July!
    20k gal, IG vinyl, 1 HP Hayward pump, Hayward 200# sand filter
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,045
    Re: Possible "dumb" question?
    Not uncommon to not have a drain in a vinyl pool. Point one of the returns downward at the deep end to help circulate the water and eliminate the temperature stratification.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    These things seem to go through cycles of popularity, my pool has only 2 returns and one skimmer, which was a very common design when it was built 30+ years ago, at the time there were lots of concerns with entrapment in floor drains (something that is again in the news in recent years)
