Results 1 to 12 of 12
Thread: Have the test kit, new results, need advice...
    I had terrible algae, got the FC up to 10, it seems gone, but pool is so cloudy.... I received my test kit in the mail yesterday, I have the new test results, I have added 2 lbs CYA in a sock:
    CYA was at below 20.
    FC = 7
    CC = 1.5
    TC = 8.5
    TA = 60
    PH = 6.8
    CH = 230
    Should I do more?
    Thanks!
    Sandra Pippa
    Katonah, NY
    IG Gunite 20,000 gallons more than 20 yrs old
    Pentair Whisperflo 1 hp
    Triton II Sand filter
    Pac FAB Multiport
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Re: Have the test kit, new results, need advice...
    Your pH is too low. In fact, it may be much lower than 6.8 because that's as low as the tester reads. It could be 5-something! So treat it with Borax or Soda Ash to get it up into the 7.2>7.8 range.
    Then resume the shock process because that CC level is still too high. Use the calculated CYA level you should be at to determine the FC level. http://www.poolcalculator.com/ can give you an estimate if you enter your pool size and scroll down to Effects of Adding Chemicals.
    OK. oops, out of Borax. Would Arm & Hammer baking soda be good?
    Thanks!
    Sandra Pippa
    Katonah, NY
    Pac FAB Multiport
    Richard320's Avatar
    Jan 2010
    19,009
    Quote Originally Posted by sandrapippa
    Thanks!
    No. Baking Soda has very little effect on pH, but a huge effect on TA.
    pool-school/recommended_pool_chemicals
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,609
    Shock at the...... NEW.........level for cya that you just added btw.
    Will do, the CYA - still a lot of it in the sock, I guess it takes a while?
    Thanks again.
    Sandra Pippa
    Katonah, NY
    Pac FAB Multiport
    Retested today after adding 5 lbs Borax yesterday and 3.5 lbs CYA the day before.
    CYA = less than 20 (it hasn't dissolved yet, but black dot finally disappeared)
    FC = 4
    CC = 1
    TC = 5
    TA = 70
    pH = 7.2
    Water is still cloudy, no change, but no visible algae now. Is chlorine ok? Should I shock again?
    Sandra Pippa
    Katonah, NY
    Pac FAB Multiport
    Jun 2012
    Howell, NJ
    977
    You haven't finished the shock process yet. There are 3 criteria, and you haven't met at least 2 of them. You follow the shock process until:
    1) CC<.5
    2) <1 ppm FC loss overnight
    3) The pool is clear.
    Sounds like you need to reread the shock process, which is conveniently linked to in my signature.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    Aha, yes, I will reread it, forgot about the CC part.....here I go. Thanks!
    Sandra Pippa
    Katonah, NY
    Pac FAB Multiport
    I remember one other question about the process. Since the CYA level is changing so slowly due to the fact that it is taking so long to dissolve - it's there in the skimmer still, and I've added the Borax, I'm trying not to vaccum and backwash since I'll be losing all those chemicals to waster. But should I backwash anyway in the midst of this procedure if the level reaches 20? That's when I usually do it.
    Sandra Pippa
    Katonah, NY
    Pac FAB Multiport
    Aug 2010
    Dallas, TX
    4,052
    That's why it's better to add the CYA to the pool via a sock in front of a return, it doesn't clog the filters, and won't be backwashed out if you backwash before it is dissolved.
    Jun 2012
    Howell, NJ
    977
    You should backwash when the pressure goes up 25% of the clean pressure.
    John
