Thread: Taylor K-2006 Test Kit Question
    Jun 2013
    North Western NC
    12
    New to testing my water but based on recommendations purchased a Taylor K-2006 test kit. When testing the chlorine the directions offer a choice of using either a 10 ml or 25 ml sample. I understand the sample size will determine the drop equivalence but was hoping to get your opinion which sample size will give me a more accurate reading or all else equal is this a non issue? Thanks in advance for your opinion.
    20k gal, IG vinyl, 1 HP Hayward pump, Hayward 200# sand filter
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: Taylor K-2006 Test Kit Question
    Quote Originally Posted by Retired084
    25 ml sample will give you accuracy plus/minus .2 PPM. 10 ml sample is to .5, which is plenty good for almost everyone. It also saves reagent.
    Jun 2013
    North Western NC
    12
    Thanks Rich, "assumed" that was the case but wanted to get the opinion of people who have been at it for for a while now.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Like Richard said the 10 ml .5 ppm per drop sample size is the right choice for almost everyone, as it is likely you may find over .2 ppm variation from one sample to another depending on where in your pool it was taken.
    Jun 2012
    Louisville, KY
    266
    The 25 sample is for commercial pools that run much lower FC levels.
    Use 10. There is no need for the added resolution in stabilized (CYA) pools.
    18x36 inground vinyl lined, Hayward sand filter and tablet chrolinator, approx 18k gallon
