Thread: Vacuum Issues
    Feb 2012
    Maryland
    400
    Vacuum Issues
    Im not sure what im doing wrong. I take the hoes and put it up to a jet and fill it with water. I then take the plate and connect the line to the plate and then stick it into the skimmer. When I do this, I see air bubbles and turbulence coming out of the jets. When I look at the pump, its not full of water its just a stream flowing into the pump. I have it set on skimmer only, no bottom drain.
    Any clue what would cause this?
    DIY 18x36 IG Vinyl Rectangle with 2 foot radius; Steel Walls. 8' steps w/t 2 step jets; 2 MD, 1 Skimmer, 2 returns; Hayward Pro Series 24 Inch 300# Sand Pool ; Hayward color logic 4.0 LED light; 2" PVC pipe 4 Jandy Valves, Hayward PL-P-4, SWCG
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,648
    Re: Vacuum Issues
    Hole in hose, water level too low, clog in line? Can you try and vacuum without the plate by just sticking the hose directly into the hole?
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Vacuum Issues
    Ditto what woody said - you'll get better results that way.
    Feb 2012
    Maryland
    400
    Re: Vacuum Issues
    Quote Originally Posted by woodyp
    Not sure I understand "just sticking the hose directly into the hole". Do you mean pull the basket out and stick the hose into the hole below that?
    Its a new hose, the water level is good.
    Apr 2010
    East Texas
    9,648
    Re: Vacuum Issues
    YEP! Just get any big stuff out first with the old net.
    Feb 2012
    Maryland
    400
    Re: Vacuum Issues
    You all rock! That fixed it. Hooking direct to the hole gave me MEGA suction. I guess the skimmer plate doesnt seat well enough
