Thread: Intex 5460
    Intex 5460
    Wondering about an Intex 5460 for my pool. Will this work with my system? Any advise is appreciated. Intex rep said no, but sounded unsure. Thanx
    2002-10.6k gal 20'x54" Rnd AG vinyl All Hayward- 150lb sand #S188T, 1.5 hp Power Flo LX #SP1515-z-1-ES
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Re: Intex 5460
    Yes it will. You may have to find adapters to connect to your existing hoses, but no reason you can't use that SWG with your pool. Whether or not it's chlorine output is sufficient for your pool I cannot say. But I am thinking it is.
    GC
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    schertzy82's Avatar
    May 2012
    Peoria, IL
    100
    Re: Intex 5460
    It will work. It may even come with the hose adapters needed. If not, you can buy them from Intex. Or if you have hard plumbing, you could also make your own adapter. See this thread. I suggest unplugging the copper bars. Given your pool size, you would need to run it about 5-6 hours per day.
    Intex 18ft x 52in Ultra Frame Pool, hard plumbed w/skimmer and fountain
    Intex 4000 gph cartridge filter pump
    Intex SWG
