Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: CYA Key to Clarity- Wow!
    Jun 2013
    Mobile AL
    31
    I am new at this but learning quickly. Can't believe how CYA effects Chlorine and how little pool stores talk about it. Guess they wouldn't be in business if they did.
    I bought the wrong test kit from leslies and am hoping to use it for now and then buy the more expensive one when I use up these chemicals. I bought the dpd kit, but not the fas-dpd. It also doesn't test CYA. So, I am going to make those pool stores that robbed me help me with testing until I finish off this kit, However, had a rude awakening with a store last night. Tell me if I am right or wrong:
    I tested: FC: 5, PH 7.5, Alkalinity is about 100. I had added borax 12 hours earlier and it showed an increase in ph from 7.2 to 7.5. Felt good, but once I started learning what CYA does, well, I still had pucks in my chlorinator. I turned the chlorinator to 0 to keep more cya from entering. We get hot sun and lots of rain here in South Alabama. Plenty scheduled for the next 2 days and last night. That's why I increased the PH to keep it from dropping to low after rain. Or, at least that was my understanding. Doesn't rain contain Acid? Doesn't it lower PH?
    Pool store numbers:
    FC: .74ppm
    TC: 2.3ppm
    CC: 1.56ppm
    PH: 7
    Hardness: 0
    Alkalinity: 81ppm
    CYA: 67 ppm
    Copper 0
    Iron: 0
    Borate: 42ppm
    They said everything was fine, just add 4lbs of shock and wait for the rain. The guy said the rain would increase the PH?! Reading the computer instructions: Add 1lb 3oz of Soda, Add Calcium Chloride, add Chlorine shock, add 2 tablets trichlor.
    Wow! He ignored everything the computer said except for the shock.
    Needless to say, I won't do any of it! I only wanted the CYA numbers and to verify what I am seeing on my own tests. I also have another cheaper test kit and strips. They agreed with my test results above.
    The rain last night pushed some silt into the pool, so I am going to vacuum to waste and add some water and then re-test shortly. My pool is clear and looks great. The Chlorine is high because I added too much bleach the other day. My results were showing 0ppm on the FC and so I added 2 gallons of 5.25. My chlorine shot up, but I was losing chlorine daily, now it is stabilizing and not losing. Because of daily rains there is a need to backwash weekly at a minimum with a small water replacement ongoing. I am going to have to learn in this weather how to maintain FC and get the CYA down. Am I correct that the CYA should gradually reduce with these backwashes and water replacements without a large drain since the CYA is 67ppm? I still have a hard time believing that their ph recorded that low.
    What a waste of money on these pool stores! I have ordered a CYA test kit from TFTestkits and it has already shipped. Just got concerned that I was already too high and might have to drain. Glad to see it not super high. I have a supply of bleach, borax and B soda. I will test daily and go to a different pool store weekly to verify results. Can't wait to get a better test kit!
    Any advice suggestions would be greatly appreciated!
    16 x 36 in-ground
    25,900 gallons
    Hayward Sand
    Hayward Northstar 1hp
    alanpaul's Avatar
    Aug 2010
    South Florida
    227
    Re: CYA Key to Clarity- Wow!
    The jury seems to still be out as to whether rain affects pH.
    We're here in S. FL and heavy rainfall does seem to make the pH rise. BUT it's NOT dependable.
    Some folks believe that it's the pounding rain on the surface of the pool, causing aeration, thus pH rise.
    There's really no clear explanation, so far.
    As you get feets and feets of rain over the course of a year there in Southern AL, and most of it in the summer, I suspect your CYA will gradually drop to where you want it, as you have discontinued using the pucks.
    Just use your test kit to be sure your FC level is appropriate for your CYA level.
    Alan in Wellington, FL - near West Palm Beach
    15,200 gal IG, painted plaster, 1988; 200 SqFt cartridge filter, 2013; 1.5 HP 1-speed pump (uprated), 2005; heat pump, 2005;
    soon to repair (dead) SWG AquaRite T-15 cell, 2005, and replace (dead) suction-side cleaner, 2005.
    Almost everything died this winter 2012-'13, and I know we shouldn't complain... but, Arrgh!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,985
    If - huge if - those numbers are correct, you have too much CC. But I wouldn't freak out, since it is such a huge IF.
    Turn off the chlorinator to stop raising CYA (and lowering ph) and just maintain appropriate FC levels for that CYA. pool-school/chlorine_cya_chart_shock
    Jun 2013
    Mobile AL
    31
    Thanks! I found the chart and my chlorine seems appropriate for the level of cya. We have a low pressure system off the coast right now, so until it passes, lots of rain today, tomorrow and maybe into the weekend. Will be watching all the time.
    I just re-tested this am: I still show 5-7ppm FC, 110 Alkalinity, 7.5ph. I'm not messing with anything right now, other than a quick vacuum and water top off!
    16 x 36 in-ground
    25,900 gallons
    Hayward Sand
    30,415
    Ignore the rain. It has very little effect on most pools.
    I understand your motivation but you are punishing yourself. Why would you go back to a place that gives you bogus advice and, especially, probably bogus test results?
    Jun 2013
    Mobile AL
    31
    Didn't know they were bogus until this morning after I re-tested and verified. Thought I could just get true results since I didn't have my cya kit yet; didn't want the advice. It was interesting that I knew they were lying or ignorant while I was standing there looking at them. My own self validation........
    16 x 36 in-ground
    25,900 gallons
    Hayward Sand
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Quote Originally Posted by skyjenn
    I am going to make those pool stores that robbed me help me with testing until I finish off this kit...They agreed with my test results above.
    +1 to what Dave (duraleigh) said. Pool store testing is notoriously inaccurate, especially on the CYA test. If you are currently using the strips to test with, this may go a long way in explaining why your results match the pool store's.
    Good choice . Retest CYA as soon as it arrives. Would also suggest the whole TF-100 kit - you will need it eventually.
    Jun 2012
    Howell, NJ
    977
    Most people say that rain has very little effect on pH, but I have noticed that it definitely lowers my pH. I assume that because I have a solar cover, that cancels out the aeration effect, but the water is acidic, which is why my pH gets lowered.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    Jun 2013
    Mobile AL
    31
    UPDATE! It has been one month since I turned my pool from dark green using only bleach. As I have been reading and asking questions I am continually astounded at how beautifully clear my water is. My pool has never been this pretty; it always looks like I just filled it. As I learn more about CYA and continue to monitor it, I made the decision to do about a 1/3 water replacement to bring it down so that I can use less bleach. I am still learning how to test the CYA and making sure I really can't see the black dot in the tube anymore, but it appears to be a little above the 50 mark. I am going to maintain at this level until I see that it is stationary. I used to dread walking out my back door because every day the pool was a surprise. We are enjoying our pool now and truly glad to see it every day. Thank you so much for this forum and for all of the support!
    16 x 36 in-ground
    25,900 gallons
    Hayward Sand
    30,415
    Very nice words about the forum (thanks) but don't overlook that the congratulations go mostly to you for your willingness to learn and your diligence to use what you have learned to become a true BBB'r.
    Butterfly's Avatar
    South Carolina
    10,045
    Now let us see a pic!
    You're done SLAMing when:
    Jun 2013
    Mobile AL
    31
    I have a pic, how do I upload it to the forum?
    16 x 36 in-ground
    25,900 gallons
    Hayward Sand
    Jun 2013
    Mobile AL
    31
    16 x 36 in-ground
    25,900 gallons
    Hayward Sand
    Jun 2013
    Mobile AL
    31
    16 x 36 in-ground
    25,900 gallons
    Hayward Sand
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I use my phone to upload pic's to the forum using Tapatalk Its very easy. Generally phones take good pic's.
    Just my 0.02.
    Jeff
    Jun 2013
    Mobile AL
    31
    I have an iphone; tapatalk is for android
    16 x 36 in-ground
    25,900 gallons
    Hayward Sand
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    You can use Tapatalk for an iPhone. I do.
    Jeff
    Jun 2013
    Mobile AL
    31
    [attachment=0:2ujtaqvl]ImageUploadedByTapatalk1373808688.108053.jpg[/attachment:2ujtaqvl]
    16 x 36 in-ground
    25,900 gallons
    Hayward Sand
    Jun 2013
    Mobile AL
    31
    Thanks! Tapatalk works great! Sorry pic is so big
    16 x 36 in-ground
    25,900 gallons
    Hayward Sand
  20. Back To Top    #20
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Good job. Looks great.
    Jeff
