Thread: skipping CYA for a few days?
    Jun 2013
    Seattle WA
    14
    I am really excited about getting my pool up and running on this Monday. I was hoping to follow the steps listed on this site for seasonal pool maintenance. The start-up steps call for 4 days of dichlor in order to get the CYA and FC up. Here is my issue. I ordered the dichlor from amazon and they are taking their sweet time delivering it. My options are to go to the local pool store and get some dichlor OR is it possible to just use bleach for two days then implement the 4 days of dichlor after that?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: skipping CYA for a few days?
    You can, but you will need to be vigilant not to let your Chlorine get too low. Without cya in a pool you will lose a lot to the sun.
    Another option would be to buy Stabilizer/Conditioner locally. This is typically close to 100% cya and would be used along with bleach/liquid chlorine instead of the dichlor.
    What size is your pool?
    30,413
    Another very viable option is simply put in about 1/2 - 2/3 cup of bleach and mix thoroughly about an hour before each time you use the pool.
    It will go away rather quickly but it will stay there long enough for you to get the sanitation that you need. If you stay in the pool longer than say around 4 hours, put in another 1/2 cup
    Jun 2013
    Seattle WA
    14
    My pool is a tiny 10'/1000gal pool. With that in mind is 1/2 cup of bleach still a reasonable amount per use (likely only one use per day)?
    30,413
    I saw that info in your sig and that's why I suggested that amount.
    Butterfly's Avatar
    South Carolina
    10,045
    Welcome to the forum
    Have you found another of your new best friends... http://www.PoolCalculator.Com ?
    You'll be able to confidently calc pool chem doses
    You're done SLAMing when:
