Thread: first test results with tf 100 - combined chlorine question
    saltwater generator
    fc - 3.5
    cc - 0.5
    ph - 7.4
    alkalinity - 120
    cya less than 20 (dot was slightly visible at 20, but disappeared when tube was full).
    1. will the combined chlorine go away with time or do i need to shock to get it to zero?
    2. should i wait till combined chlorine gets to zero before raising cya?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: first test results with tf 100 - combined chlorine quest
    Ignore CC that is at or below 0.5 ppm.
    Start raising cya now. Our recommended level is 70-80 ppm cya for swg pools, but be careful...cya is easy to add but drain/refill to remove.
