Re: Silly question
Sorry!
I was actually trying to add to the topic by sparking discussion through posing another question that I felt was very much related to the OP's original inquiry.
I felt what would be discussed as a result may have further benefited the OP.
I do apologize for my misjudgement.
Thank you for moving the post so it didn't interfere in any way.
With that said, since this is now a separate thread. I have been meaning to ask about burying wire. Is it advised in cold climates to bury it below the frost layer, if so, how do you go about determining frost layer depth?
Edit: With residential homes that have a pool out back and the home's electrical panel on the inside of the garage, at the front of the house. How is an electrical run most effectively and easily accomplished in this situation? One of which I imagine is rather common.
The power drop comes in underground and up through large pvc conduit into the meter box all on the outside of the garage. Then from there, through the garage wall and into the one and only panel on the inside of the garage.
I have an outdoor electrical outlet on the backside of the house already. But IIRC, It's not its own circuit. So that may not work to tie into it.
Note: I changed the title of the thread so it more closely relates to the discussion.
