Results 1 to 8 of 8
Thread: Heater and pump questions
    Jun 2013
    Southeastern British Columbia
    79
    Hi pool lovers I am beyond excited! We purchased our 13 x 22 foot ultra frame pool a few days ago!! Planning on getting instal going when we get back from vacation. Here is the plan: digging out yard down about 2-2.5 feet with about 2 feet of extra space overdug to set up pool in the "hole" and the. Building a wooden deck around it with hot tub. We have got a solar cover and reel stand that we will put up, along with some other stuff that is coming off a few defunct inground pools we have found. We are going to change the plumbing to PVC and add a 1 hp pump and a sand filter.
    Also considering a 212000 btu natural gas tropical aisle pool heater. We are wondering if there any substansial reason putting that kind of heater with this pool would be a problem?
    Also thinking of looking into converting to propane if natural gas isn't feesible. Anyone done this?
    Thanks for taking time to read my long and boring posts.
    13 x 24' x52" ultra frame pool (still in the box)
    Going to be set in 2.5' hole with deck at rail height sourounding entirely
    Cartridge filter ( we will see how that goes for one season)
    Natural gas heater and solar cover
    Plan to use bbb method! Yay!!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Heater and pump questions
    Heating an intex is fine. Generally natural gas will be much cheaper. Conversion is typically possible, you need to change jet orifice size to do it.
    Jun 2013
    79
    Thank you for the reply! Do you know others here who have used an inground pool Heater within above ground pool?
    30,415
    If you are digging a hole for your pool, the rainwater will fill that hole (as in a muddy mess) unless you have provided an escape path for the water.
    Jun 2013
    79
    Oh good thing you've mentioned that! I will be sure to check into that!!
    Thanks
    Jun 2013
    Erie pa
    68
    The heaters are the same, the "inground heaters " are just generally higher btu ratings because inground pools usually have more water to heat.
    16x32 vinyl ig with foxguard steel walls,gli liner ,hayward de filter,hayward heatpro heat pump,hayward colorlogic 4.0 led.pentair circular weir skimmers.hayward sharkvac xl robot,gli mesh cover.polk atrium speakers,sonos music system.erie pa.
    Jun 2013
    79
    Do you suppose if we go that route that the cost to run would be significantly more ? The reason we are going the route of the inground heater is because it is coming off a pool that is being closed in and they are selling it to us for only $200
    We are on a budget. Including the pool, which cost $1000 and a deck which I have no idea of the cost we need to be under $5000.00
    Jun 2013
    Erie pa
    68
    The cost to run would be the same.if your heating your pool i highly recommend a solar blanket to slow down heat loss at night.
