Thread: Clear but with a green tint?
    We opened our pool this spring after taking last year off, expecting to take some work and time to clear up our water. We are now at the point that our water is clear,but with a slight green tint. The pool store guy was just sure we had phosfates, I told him I thought it was metal I was right,we tested high for copper & added Metal Free. But still have a slight green tinge. We do have some staining, could that be causing our off color?
    Pool specs are: 18x 36. 40,000 gallons.
    Chemical reading: Th 200
    FC 3-5
    PH 7.2
    TA 80-120
    CYY 100
    We are trying to get our CYA down as we know that is high.
    Any feed back would be helpful. Thanks
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Clear but with a green tint?
    Welcome to tfp, Deb6234
    You are right you cya is too high, we would recommend getting it down to 50 ppm....but is that result from a pool store? They tend to be very unreliable at testing cya. In addition, many tests show 100 even if the concentration is higher. See this link for appropriate test kits: http://www.troublefreepool.com/pool-...kit_comparison
    If you water is tinted and clear, and you have staining it is likely metals as you suspected. The sequestrant you are using is not one that we recommend. See this pool school article: http://www.troublefreepool.com/pool-...metal%20stains
