I will be receiving a 18x33x54 agp. The ground is prepped and I have decided to use foam. So far, all I have seen are videos and read info on installing pool. In the video after leveling buttresses, there is a strap that runs across from each other. That don't seem to be a problem. But they also layout some pressure plates. Am I supposed to lay the foam right on top of that, if so, won't that cause a bulge on the liner floor? Does the foam need to be cut to fit exactly in the circle or oval in this case ,or does it extend way past everything?
