Results 1 to 16 of 16
Thread: What to do with DE?
    jcowart's Avatar
    Jun 2012
    Labelle, TX
    320
    What to do with DE?
    What do you do with used DE. I have a well used pillow case on the end of my backwash hose. I might add that I have a perflex "bump" filter so it's gravity backwashed and not under pressure. I ask because my brother-in-law went from a sand filter to a house with an I/G pool and DE filter. The first giggle I had was when he said "I guess the sand goes in that thing". We took it apart and gave it a good cleaning but I noticed the leftover mess from all the backwashes.
    17500 gallon Doughboy AGP, Hayward DE filter, waiting for the 1.5hp DB pump to go out.
    Learn to take the advice here and be trouble free or use the pool store's advice. "You can't do both and get very far"
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: What to do with DE?
    It depends on your location, in many / most areas you can wash it down the drain
    jcowart's Avatar
    Jun 2012
    Labelle, TX
    320
    Quote Originally Posted by Isaac-1
    Yes that's the norm for city folks, we both use aerated septic systems. I just let the pillow case drain and dump a clump of DE on the burn pile. His is just out in the yard and it looks like a mess. We tried a pillow case on his but it just shot off the hose. I don't think it could drain fast enough. Like I said, mine is well used. You can't quite read a news paper through it but it's close. Just looking for ideas when down the drain or sewer is not an option.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Perhaps mix it with some sort of clumping agent and dispose with the regular trash?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Use it for a late-night snack...as a topping for ice cream... mixed with sour cream for a zesty dip... just kidding.
    If you've got some land, scatter or bury it. It's supposed to kill insects.
    Or say goodbye to the pillowcase and chuck it all in the trash...or a dumpster behind some business, late at night.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    If you want more excitement in your life take it to any Federal building and ask them how you can dispose of your bag of fine white powder
    tcat's Avatar
    May 2012
    Austin, TX
    731
    If you have a garden, you can put it at bottom of plants to keep insects away.
    IG pebble, 15,000 gallon
    48 PentAir DE Filter with backwash valve
    PentAir Whisperflo pump with 1hp 2-speed motor
    Aquabot 4WD, Poolskim
    Intermatic Dual Timeclock with freezeguard
    DIY chlorine feed
    BBB
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    I will normally place the used DE in my "green" waste bin for collection as we get regular collection of yard waste.
    -- Guy --
    Aug 2010
    Dallas, TX
    4,052
    I literally laughed out loud!
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Switch to cellulose, problem solved.
    It does cost a bit more, but DE cost is pretty minimal in operating a pool. It does a better job, Eco-friendly, bio degradable and safer to handle.
    chiefwej
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    I though mine over the fence, not sure what my neighbor does with it.
    40'x19' IG Diamond Brite 29K 4' Waterfall/Dive Rock FNS60 DE Inteliflo VS 2hp Whisperflo pumps Aqualogic(P4) SWG TF100 Tester
    Pool School, Pool Calculator,TFTestKits,
    jeremy's Avatar
    May 2013
    Oceanside, NY
    54
    I am confused about this whole "used DE" conversation. How are you collecting used DE powder?
    The one or two times I backwashed, the dirty water went all over the place. I still haven't quite figured out where to direct the backwash, though i bought a long enough hose to dump it anywhere in the yard...
    POOL SPECS: INDOOR, 22.5k Gal, Vinyl Liner, L-Shape, In-Ground, Main Drain (2), Skimmer (2), Water Slide, No Spa/Water Features (Dimensions, Pool Pic, Panoramic Pool Pic)
    HARDWARE: Jandy DEV60 Filter / JEP1.5 VS ePump / AquaLink RS Controller, Sta-Rite SR400NA 400k BTU Heater,
    tcat's Avatar
    May 2012
    Austin, TX
    731
    Mine drains into the yard and then a pond. I never saw any white powder lingering. I switched to Zeofiber at the end of last season. For as little as you use, it really doesn't cost much and does a great job.
    DIY chlorine feed
    BBB
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    For me, the easiest is to take the head off the filter, let the DE settle, remove the union, lean the filter body over to our out the water (leaving the DE slurry in the filter body) and then pour the dirty DE slurry into my green waste can over the yard waste that's already there. I then leave the lid of the waste can open to encourage evaporation of the water. I can lift my filter body and dead DE pretty easily and carry it to my front yard.
    I have converted over to cellulose except for this season I found one bag of DE in my garage. So this summer I am using DE. The cellulose is rinsed to the ground behind my filter. it's just fancy saw dust in my mind.
    My new PoolSkim is taking most of my waste load off my filter. I now get very little debris into my skimmer body. the Pool Skim removes fist fulls of crepe myrtle blooms each day and they never get into the filter. I can now vacuum (via aquabot DiverDan) twice a week and be fine.
    -- Guy --
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Quote Originally Posted by jeremy
    Well, my system actually has a separation tank that strains the used filter media out of the back flow water. They are required in some areas.
    chiefwej
    jeremy's Avatar
    May 2013
    Oceanside, NY
    54
    Quote Originally Posted by chiefwej
    Hmm, is that recommended to use if I will be dumping the backflow water onto the lawn?
