Thread: Dead algae
    Sep 2007
    Georgia
    30
    Dead algae
    I am almost finished clearing up and outbreak of algae. My water is still a little hazy. Is this the dead algea? Will 24/7 filtering w/ my sand filter clear up the haze?
    16 x 32 IG Vinyl
    Sand Filter
    30,421
    Without test results, everyone can guess at the answers but they will be just guesses.
    Do you have a set of current resuilts you can post?
    whoozer's Avatar
    Apr 2008
    Acton Maine
    633
    We need test numbers to help
    14x33 fiberglass freeform
    Variable speed Pentair intelliflo superpump
    420 Clean and Clear Plus cartridge filter.
    pool-school/pool_calculator , http://www.tftestkits.net/
    I'm assuming you shocked the pool hard with bleach?
    If so, and it's been a few days at shock level, then probably the algae is dead. You will need to brush the sides and bottom of the pool, but if it's dead it should come off easily (live algae remains stuck to the surfaces). Color also changes from green to brown, although the entire pool can appear deep blue and cloudy. At this point, vacuuming, brushing, and filtration should clear the pool.
    However, as said above, you need to test and monitor your chlorine levels so that you can be sure you've maintained shock levels of chlorine for enough time to kill the algae.
    I had green algae when I started this season. I went up to about 30 ppm chlorine and maintained this for about 4 days. The first day, the pool started to look less green, but I still couldn't see the bottom. By day 2, I could see the bottom, but it was very murky and brownish/bluish. By the third day it was pretty clear, and by the 4th day it was perfect, and I started to let the chlorine levels drop to normal while brushing and vacuuming to get rid of all the dead algae.
    Sep 2007
    Georgia
    30
    I've been keeping my chloring level at 20 pppm for the past 4 days. Water was clear and then I noticed green growing on wall near light and on steps. Green is gone water is grey blue with haze.
    CC-0
    CYA 50
    Tot. Alk 140
    Ph 7.3
    Water temp- don't know but warm water
    I use TFP test kit
    16 x 32 IG Vinyl
    Sand Filter
    It's probably dead algae, but I'd keep the chlorine level up until it's crystal clear. That is what my pool looked like a few days after I started shocking, and it took my filter (DE) a few days to clean it up. Vacuuming is also very helpful to stir up the stuff on the walls/floor and help circulate the water.
