Thread: Why the need to wipe between drops when testing for TA?
    Jul 2012
    Herndon, VA
    419
    According to the directions in the TF 100:
    "Add r-009 one drop at a time, swirling between each drop. Wipe the tip of the bottle after every drop with a damp cloth"
    Is this really necessary? What difference does it make?
    8,000 gallon, in ground, fiberglass pool with a cartridge filter.
    Re: Why the need to wipe between drops when testing for TA?
    Static electricity can build up on the dropper tip, which changes the drop size, and throws off the test results. In theory this can happen to any of the tests involving dropper bottles, but in practice it is only at all common on the TA test. A damp cloth/tissue shorts out the static charge, restoring the drop size to normal.
    38,305
    This also only appears to be a real problem when the kit is new. The drops were practically shooting out of mine new kit. Now it appears there is no more issue.
    30,421
    Yeah, it is a transient condition usually lasting only a couple of weeks.
    Too many newbies read that and start wiping down every reagent on every test.....total waste of your valuable time. I have never seen it on anything but the R-0009.
    HamburgerChef's Avatar
    Apr 2013
    Indianapolis Indiana
    100
    Good to know. I have a new kit and have been having weird #'s. Maybe I am not totally incompetent after all.
    13,500gal AGP Matrix 24'
    Pentair Sanddollar SD-80 75GPM filter, Pentair Dynamo 1HP 2 speed pump
    Polaris 65 pool cleaner
    (20'x30" solar heater to be installed)
    Jun 2012
    Louisville, KY
    266
    You can tell if this is a problem. You get "small drops". It's difficult to describe but the best way is you don't see those "nice, plump, full drops" that seem to drop from their own weight. Believe it or not a drop is a fairly accurate and consistent measurement based on surface tension.
    18x36 inground vinyl lined, Hayward sand filter and tablet chrolinator, approx 18k gallon
