Results 1 to 8 of 8
Thread: Taylor test results for new fill in! FINALLY!
    Haley's Avatar
    Jun 2013
    Washington
    73
    Hi all!
    So this is my first time using my Taylor K2006 kit. Hopefully I got everything correct:
    TA: 140
    FC: 5.5
    PH: 7.3
    CC: 0
    CH: 180
    Didn't test for CYA because I put in 24 oz of stabilizer in this morning along with my 37 oz of bleach for my new fill, and from what I've read it doesn't really register for a week or so and I don't want to mess with it until someone thinks I should. But my sock-full is pretty much dissolved.
    Going to check now against the Recommended Levels at Pool School and visit the calculator if they're in need of adjusting.
    Intex 15'x48" AG metal frame pool (4,440 gal), Krystal Clear (1600) 14" sand filter, Taylor K2006 test kit, Intex Deluxe Maintenance Kit/vacuum (love it!), Intex Deluxe Skimmer, BBB.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: Taylor test results for new fill in! FINALLY!
    Sounds like you are heading in the correct direction!
    -- Guy --
    Haley's Avatar
    Jun 2013
    Washington
    73
    Awesome! TCJ4, I'm not sure about the answer to that since I haven't tested for CYA yet... Hopefully someone can answer that question for us.
    More questions I have for anyone:
    -When are we able to swim? I'm assuming I don't have to shock?
    -Before people swim, I noticed that some add a cup of bleach to the pool? Is that helpful?
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    I would say to "assume" the CYA is in the pool. So, if you added enough CYA to get you to 40PPM, enter 40 in to the "measured" section of PoolCalculator and use the levels it provides. In this case, a 40CYA suggests a 3-7 PPM FC range. So your FC of 5.5 is mid range and perfect for swimming!
    Tonight, after the swimming is done, measure again and bring it up to 7 (or 8 if its going to be hot and sunny). Lather, rinse, repeat everyday adjusting each level based on your results and the recommendations of the poolcalc...
    If you keep getting low evening numbers, adjust your FC goal up (10?) or add more CYA, but this is for another day.
    -- Guy --
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    As to adding a cup of bleach before swimming, that is essentially what you are doing "after" the swim. You will be "feeding the pool" bleach each night like your family pet. If you skip a night your "pet" may get cranky and turn green on you and require more food the next week (shocking the pool).
    If you feed the pool the amount the FAS_DPD test tells you to everyday, your pool will be sparkly clean every day.
    -- Guy --
    Haley's Avatar
    Jun 2013
    Washington
    73
    Thank you so much- that is great information! ..."family pet"
    30,419
    TCJ4,
    Do not hijack another's thread. It is impossible to answer questions when two people are asking. I have moved your posts to your own thread.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    TCJ4,
    I have seen your comments about what you are doing in several threads today but I have not seen a thread addressing your issues.
    If you make comments in several diverse threads, we cannot help. We need all of your comments and concerns in one place where we can understand the whole problem. Trichlor is not typically the recommended method here at TFP.
    -- Guy --
