Results 1 to 12 of 12
Thread: one long pump run or several shorter
    Jul 2012
    Whidbey Island, WA
    397
    Hi
    Is it "better" to run the pump say 9 consecutive hours or
    3 periods of 3hours each
    thank you
    IG under fir trees and one cherry surrounded by grass built in 1979, 30k, plaster, old Sta-Rite HRPB30, 4.9 sq.ft, 20 GPM/sq.ft., but with new glass, new (in 2012) 1 HP WhisperFlo one speed, new (in 2013) Rainbow tab chlorinator attached at the top, old Maxi-Flo Heat Exchanger MF-260, Burnham V7 oil heater 245 MBH, new (in 2012) Compool to Easytouch, Taylor K-2005 and TF-100.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,572
    Re: one long pump run or several shorter
    I say break it up if you can with a timer if you can.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    In the summer I run a short cycle early in the day to hopefully push things towards the skimmer and equalize the temperature throughout the whole depth of the pool. The main filtering is later, when i have time to test and dose.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Yes, it is better to break up the run time if you can but three 3 hour segments is way too long. You might try three 1 hour segments and see if that works ok.
    Have a read: pool-school/pump_run_time
    Mark
    Jul 2012
    Whidbey Island, WA
    397
    Quote Originally Posted by mas985
    thank you all
    Ok, would seriously like to reduce pump run costs but...
    have been told that total pool volume (30,000) should be circulated once / day and that that takes about 8 hours
    so not true, do not need to run 8 hrs to exchange total volume?
    mas985's Avatar
    Pleasanton, CA
    11,737
    No it is not true. Read the link I posted.
    BTW, what model pump do you have? 8 hours is pretty low flow rate for a 30k turnover.
    Mark
    Jul 2012
    Whidbey Island, WA
    397
    have done
    will do
    outcome will be interesting (and cheaper)
    thank you
    Jul 2012
    Whidbey Island, WA
    397
    WhisperFlo one hp
    I think model is WTE-4
    I tried to calculate time to turn over but failed
    mas985's Avatar
    Pleasanton, CA
    11,737
    Probably a WFE-4. A WFE-4 will produce about 80 GPM on 2" plumbing for a turnover of about 6 hours.
    Also, what is your method of chlorination? Unless it is manual, that will need some adjustment for the reduced run time.
    Mark
    Jul 2012
    Whidbey Island, WA
    397
    ok, 6 is 2/3 of 9 so cost down to 2/3, nice
    chlorination? Rainbow 320, set on setting #3, about 1/2 filled with tabs, and has the inlet at the top
    mas985's Avatar
    Pleasanton, CA
    11,737
    I didn't mean to imply that you had to run 6 hours. I current run my pump 4 hours per day which is about 1/2 turn per day so you might be able to get away with 3 hours per day which is why I suggested 3x1 hour runs.
    As for the chlorinator, because of the reduced run time, you will need to adjust that for more in less time.
    Mark
    Jul 2012
    Whidbey Island, WA
    397
    is getting better and better, 3 is 1/3 of 9, lots of kWh saved
    which is serious on Whidbey Island (near Seattle) as the pool is empty lots of the year
    with Rainbow at 3 and half filled, there is plenty of room to increase
    so why do I have a pool? was here when we bought the place
    and by the way was green when we arrived, so green could walk on the water
    now is clear, grandbabies will swim tomorrow; maybe me too for that matter
    thank you again
