Results 1 to 8 of 8
Thread: confused about "normal" and acceptable PSI
    So I have read probably 20-30 threads on this forum and other places on the Internet about PSI but still a bit confused.
    Is there really no "normal" PSI and instead you should just see what your pool is at when filter is cleaned, skimmers are cleared, etc? I ask b/c my pool is a year old but I just got it in a house we bought and I am not convinced that the previous owner was very good at maintenance based on some issues I have seen with it and have had to fix, so I do not really trust the "normal" PSI.
    Also, I just replaced the PSI gauge today as the old one never moved above 0 and for some reason I never quite put together that it was broke, just thought the PSI was super low (I know how stupid this sounds now).
    With the pump running on the high setting (has high and low), the pressure reads at 19.
    In the last 24 hours I have added salt to the pool and shock through the skimmer. I don't know if these affect PSI but wanted to list them in case it does.
    Should I consider 19 to be in the normal range since I cannot really baseline from when the pool was first installed? If not, what would be a normal reading.
    I want to use DE to get the pool clearer, but first I want to make sure the PSI pressure is reasonable.
    Pool Info: 15,000 gallons, In Ground Pool
    22,551
    Re: confused about "normal" and acceptable PSI
    Each individual system is different but 19 psi sounds in the common range.
    If you've cleaned your filter and have a new gauge take the reading as normal. Don't overthink it too much.
    30,427
    +1 what bama said.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    My normal PSI used to be 8 clean, then I changed gauges (died) and it went to 10 clean, I made some plumbing changes and added a PoolSkim and the normal is now 18 clean (I need to fix the plumbing)
    -- Guy --
    BobbyR's Avatar
    Jun 2013
    Toronto, Ont
    142
    My normal PSI was 13 for several years. Never changed. Never thought much about it. Then, one day I looked at it when the pump wasn't running. 13.
    $7.99 for a new gauge and my new normal is 17 PSI.
    Lagoon 40x22, Vinyl, 27,000 gal, 1HP WhisperFlo Pump, Pentair 60 gpm Sand filter, Hayward Brominator (used for chlorine pucks only when away), Rheem gas heater, Dolphin M4 Robot
    Waterfall on separate dedicated pump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,045
    It all depends on how long the pipe runs are, how big are the pipes, even how big the return eyeballs are.
    You'll know after you backwash what clean pressure should be.
    mas985's Avatar
    Pleasanton, CA
    11,741
    Depends on pump "size" too.
    19 PSI is high for a 1/2 HP pump on 2.5" plumbing but is low for a 2 HP pump on 1.5" plumbing.
    Mark
    Thanks for all the help!
