Results 1 to 7 of 7
Thread: Backwashing DE Filter for First Time
    Apr 2013
    Dallas, TX
    59
    Hi, as I mentioned in my intro post, I just bought a house with a SWG pool and I've been using the BBB method w/ TF100 test kit from the start for a perfectly balanced and, thus far, easy pool owning experience.
    That being said, my filter pressure gauge has slowly been increasing ever since I bought the house and is now approaching the 25% mark. The pool levels are all fine - I'm sure it's just from all the leaves and debris that I get from having 3 trees hanging over the pool.
    I bought some DE (HE brand "Filter Aid") because I know backwashing will require replacing 80% of the DE, but I was wondering if someone could walk me through the backwashing process. I've never owned a pool before this, so if you could break it down to baby steps, that would be really helpful!
    Thanks
    ~15k gal IG pebble pool/spa w/ water features, Goldline ProLogic + SWG, 2x Hayward Northstar pumps, Hayward Booster Pump, Hayward 60sqft DE filter, 400k BTU Hayward heater, Hayward Viio Turbo pool cleaner, TF100 test kit
    Jun 2011
    Long Beach, CA
    2,790
    Re: Backwashing DE Filter for First Time
    Mar 2010
    Spring, TX
    1,082
    This may help some. I was worried the first time I cleaned my DE filter when I had one, but once I was done I was like that was easy. Here is a video I found on youtube. You may want to google your brand and see if there is a video.
    http://www.youtube.com/watch?v=BHIZYr5TCnc
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Tip: unroll the backwash hose carefully and make sure there are absolutely no twists or kinks in it. It will balloon up and pop so fast you won;t believe it - and probably at the worst possible location.
    Apr 2013
    Dallas, TX
    59
    Hm, I don't know that I've seen a backwash hose...
    Jun 2011
    Long Beach, CA
    2,790
    Is the waste port plumbed to a drain? If so you are all set.
    Apr 2013
    Dallas, TX
    59
    I guess it is, because I did the backwash yesterday and didn't see any water coming out anywhere.
