Thread: New to pool - Panic shock
    I just moved into a new house. In addition I'm new to maintaining a pool.
    I thought I had an algae problem, light brown stains on the floor that appeared to be growing thought-out this older concrete pool, so I shocked the pool. Two small sections looked to be blackish? The water is clear. I bumped the chlorine up to 24 FC and lower PH to 7.4 and started to scrub with a metal brush, but there was no notice improvement, three days later the FC is currently at 18. The CYA is down to 50 due to rain and some draining / filling of water.
    It's an oval concrete pool about 40X18 with an 8 1/2 foot deep end.(est. 28K gallons?) The pool readings were initially below when I started the shock:
    FC - 1.62
    TC - 1.80
    PH - 7.8
    Alk - 115
    Hrd - 150
    CYA - 60
    All readings are per a color Q pro7, left by the previous owner. The shock readings may be subjective, as I read the Q has limits of 10 concerning FC levels. ( one must measure 1/2 cap full of the test bottle (10ml) and then multiplied by five). I'm not confident in the readings, as they tend to very if I test back to back. I have ordered a new test kit to confirm the readings.
    If it's a metal issue, would the shock have worsened / contributed to the staining? Vitamin C seemed to help the staining on my stairs?
    FYI - The pool "guy" came by today to help fix a problem with a leak in the Polaris pump and stated that he thinks that it's metal staining.
    28K gallon concrete pool ? - Built 1974 (re-conditioned 2002?)
    Polari's pump and cleaner
    De filter / 2 hp pump
    Hayward gas heater
    Fiber optics
    Compool
    What's my best action to fix the metal staining? Similar to chlorine there are so many options...
    Thanks much - Just learning
    24,000 gal IG Gunite, Hayward NorthStar 2HP pump, Hayward 425 sq' cartridge filter
    Hayward Viio Turbo cleaner, Water Quality Pure Ozonator, built March 2010
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: New to pool - Panic shock
    First, determine that it is metal staining. It's easy! Get a Vitamin C tablet - if you don't have any, the cheapest generic at the drug store is fine - and set it on the black spot for about fifteen minutes. If there's a white spot where the tablet was....it's metal.
    Use the search box - up on the top line next to logout for metal stains for a lot more information. Also check pool school, there's an article on metals and staining.
