Thread: Ground wire
    Ground wire
    This is my first time putting the filter together by myself... I have a green ground wire coming from underground..where do I attach the ground wire to my Hayward filter? Pictures would be great along with directions, as I am a visual learner. Thanks so much!!
    Deebers
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    Re: Ground wire
    That is called the bonding wire. There's probably a lug on the metal case of the motor for it. Something like this:
    Jul 2008
    Flintstone, GA USA
    112
    Re: Ground wire
    A filter has no ground or bonding wire attachmdent
    Tom
    18 x 36 Grecian Polynesian Fiberglass Walls with Concrete bottom - 3 ft to 9 1/2 ft. deep -
    Hayward Variable Speed Super Pump SP2600VS 1 1/2 True HP,Hayward sand filter S200, and Hayward auto clorinator. Hayward 250,000 natural gas heater. PoolKeeper automatic water leveler. Loop Loc Ultra Solid Safety Cover. Hayward Color Logic 12 volt light. Dual Pool Deck Jets.
    Polaris 380 auto cleaner. Trouble Free Test Kit TF-100.
    Re: Ground wire
    Hi Richard,
    Can you tell from these pictures where the ground needs to go on the filter base?
    Deebers
    Richard320's Avatar
    Jan 2010
    19,004
    Re: Ground wire
    That's where it goes! Just stick the wire in the square opening and tighten the setscrew
    Re: Ground wire
    Awesome....Thanks so much, I really appreciate it!
