Thread: Metal in the pool question
    I had a waterfall put in recently. Concrete formed molds. To install it, they put a metal wire mesh from the waterfall down inside the pool under the water and attached it to the pool wall. They then applied a concrete mix over the mesh, molded it and painted it.
    My concern is the metal mesh used. Although I can't see behind the concrete they put on, I am pretty sure that some of that metal has to be exposed behind it which gets wet and is under water due to leaching holes.
    Can this metal this eat pool chemicals? Recently the pool won't hold chlorine even though the stabilizer levels are fine. It is getting green.
    Thanks
    13000, AG, Plaster, Pentair equipment pump salt, automation, 3hp pump, 11 years old, TF-100 test kit, city water, pool cleaner vac, South Florida
    22,550
    Re: Metal in the pool question
    The metal won't have any affect on the chlorine level. You need to perform the shock process.
