Thread: New pool, figuring out testing. PH/TA questions
    Hi all,
    I've got a new IG gunite pool that's been operational for about 4 weeks. It's about 25,000 gal.
    My plan all along has been to maintain my own pool since I'm able to deal with it daily instead of waiting for a visit from the pool guy. We've got a pool guy coming once a week as part of the build, so I've been trying to match up my chem readings with his.
    I'm using the TF-100 test kit, and I can't seem to match up my PH and TA readings with the pool guy. Last monday, he said I had 90 TA, but when I did the test (multiple times, different parts of the pool), I keep getting 20-30. Also, my PH seems lower than his, but I'm just using the blue test kit, which I don't think is exact.
    I'm *guessing* that he's right, and I'm wrong, but I want more proof. Is there another test I can use to verify? Is it possible I'm doing something wrong in my testing?
    Thanks for any advice I can get!
    -bobby
    Bobby
    Austin, TX
    25,000g freeform gunite with spa;
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Re: New pool, figuring out testing. PH/TA questions
    I am guessing YOU are right. If you followed the instructions multiple times for TA for example, and got the same reading, trust YOUR tests.
    GC
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I wouldn't assume he is right. Do you know what he is using to test?
    Post your full test results.
    Jul 2011
    844
    Yes I do. He said TF-100.
    Bestway SWG
    Test results as of about an hour:
    FC: 3.5, CC: 0
    TA: 30
    CYA: Hard to say. I thought I could see that black dot the whole time, but at 20, it was hard to see.
    Also, by the time Monday rolls around, Chlorine levels are < 1, and the pool guy dumps a bunch of chlorine, and I'm out of the pool for 8 hours every monday. That seems wrong to me.
    PH (from the blue kit): Looks b/w 6.8 and 7.2, so I'm calling it 7.
    Bobby
    Austin, TX
    22,542
    I think you're both agreeing. I think Linen was meaning that we shouldn't assume that the pool guy was right.
    I agree with both of you. I think Bobby's test is right, and I don't think the pool guys were. How's that for walking the fence?
    Bobby -- You'll do yourself a huge favor by taking over the maintenance of your pool yourself.
