Results 1 to 7 of 7
Thread: clarifier
    clarifier
    I bought HTH Natural clarifier at wal mart for my cloudy water. It states to put in and run pump for 6 hours, but can you put it in right after you put in Chlorinating granules? Or do you have to wait? And can you swim after adding the clarifier? It doesn't say on the bottle. ( My ph levels are fine, about 7.2+)and my cl levels are also ok, but my water is a little cloudy, so I thought the clarifier would help) Thank You!!
    18' AG Intex pool, 1500 GPH Wet Set Pump, HTH 3way test kit, HTH chlorinating granules 47.6% calcium hypochlorite, Myrtle Creek, Oregon
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: clarifier
    What type of pool do you have?
    What filter system are you using?
    Where the the "cloudy come from? What have you done to the pool recently to make it cloudy? It could be as simple as running the filter longer with a higher level of chlorine.
    Adding a clarifier may actually make it harder to clear up you pool.
    If you have "dead algae" making your pool cloudy, you may be able to let it settle and vacuum it directly to waste. Sand filters can be slow to filter out fine debris. The PoolSchool link above can show you ways to improve performance.
    -- Guy --
    22,548
    Re: clarifier
    Welcome to TFP.
    Please post a full set of test results and how you got them?
    What is the ingredients of the chlorinating granules?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: clarifier
    Welcome to tfp, gageman22
    Generally we do not recommend the use of clarifiers. Instead we encourage figuring out the cause of the cloudiness and fix that. Then often the cloudiness will go away on its own without clarifiers.
    Read this pool school article and post some test results: http://www.troublefreepool.com/pool-...efore_you_post
    Re: clarifier
    I have an 18' Intex above ground pool. It has been cloudy since I put it up, but I think you may be right. I didn't have a test kit, and I just got one, and added all the right stuff to bring the PH and cl levels where they are supposed to be,, and it is getting clearer. My chlorine granules are 47.6% calcium hypochlorite. I just checked again, and it is getting clearer. I think I will do as suggested, add a little bit more chlorine( right now it is showing right at 7.2 PH, and about 1 cl, so I should be OK to add a little more, right? I have the HTH 3 way test kit, and the 1500 gallon intex filter pump. Thanks for the answers, I am new at the pool game, and just want to be sure all is OK, before the kids get in!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Re: clarifier
    [center:32hs7hqh][/center:32hs7hqh]
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: clarifier
    Depending on your CYA level, you may need to get your CL level up to 10 PPM or more to clear up an algae bloom. A full set of reagent (drop) based tests will really help solve this problem.
    Pool stores will suggest a $$$ cart load of stuff to solve it. We will recommend chlorine (and other simple chems from the grocery store) based on test results.
    Sorry to say, but you may need read and understand the articles in Pool School for this to make sense.
    -- Guy --
