Thread: pool store numbers
    pool store numbers
    Switched to a swg about a week ago. Waiting for my new test kit to get here. In the meantime I had a store test my water and it was showing the following
    Fc 6.02
    Ta input 66
    Adjusted ta 49
    Ph 7.6
    Cya 51( added solid a week ago)
    Ch 83
    Si -0.4 corrosive
    Telling me to increase TA and CH. Us this correct ?
    21100 gal vinyl lined
    21000 gal vinyl lined in ground
    36 sq. ft. DE filter with Hayward 1.5hp VSP
    SWG chlorine
    Massachusetts
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    Re: pool store numbers
    Nope. Vinyl pool doesn't care about low CH - there's no plaster to etch.
    I don't know the difference between input and adjusted TA. They're slightly low, but not so far out of whack that I'd rush to fix since pool store results are usually off.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I agree with Richard, sounds like they were just trying to get you to buy stuff
    Ya that's what I figured. I think they are still upset because they lost good business since I found this site.
    SWG chlorine
    Massachusetts
