Thread: Lots of water blowing out polaris 280 pressure relief valve
    May 2013
    Fort Lauderdale, FL
    423
    My polaris 280 has a lot of water flowing out the pressure relief valve at the wall connection. Is that normal? I haven't pulled the hose off to see if the blue disc is in there or not.
    45'x12' 17k gal, IG plaster, Pool Pilot Nano+ SWG, 1/2hp Whisperflo pump, PAC-FAB TA-60D sand filter, Raypak 266 heater
    Pool School + Test Kit + Pool Math = Trouble Free Pool
    22,548
    Re: Lots of water blowing out polaris 280 pressure relief va
    It could be normal. Is it a lot more than it was previously?
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Mine blows a significant amount out of that valve, i made it so my valve points down, otherwise it was pushing a column of water up beyond the water line, kind of bubbling up (without the bubbles).
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    May 2013
    Fort Lauderdale, FL
    423
    I read that it's normal from a few others posts. I'll check my RPM's and make sure they're 28-32 today.
    Re: Lots of water blowing out polaris 280 pressure relief valve
    Reviving the thread - looks like there are many of these observations about that relief valve for the Polaris cleaners - I have a 380, and after some years, the water coming upwards from that relief valve has increased, with that came a slow down of the cleaner.
    The booster pump is the same and I have taken apart, from the hook up at the outlet in the pool wall, to the cleaner itself with replacement of the bands that move the wheels.
    In one of the many threads about this subject, someone, after replacing the relief valve twice, took it out and put a plug - Polaris will of course say extreme and may damage the internals of the cleaner, but the poster claims that it brought the cleaner to its original speed and performance.
