Results 1 to 15 of 15
Thread: i Just need some confirming help!! just a noob!!
    I am looking to purchase a 40 x 18 x 54 Sharkline Matrix. The Matrix seems to be a good quality pool that will last (so the dealers say). If not this pool I was looking at the Swim N Play Navigator (aluminum). So I am still not quite sure which to buy, but I want a pool that will last.
    I was leaning towards a cartridge filter with the pump., can someone tell me if this pump would be good for the 40 ft. sharkline pool? Or is it overkill?
    http://www.poolsupplyworld.com/Pentair- ... OF2160.htm
    I want a good quality pool and pump and filter system, something that will last.
    Can someone please chime in, thank you!
    22,553
    Re: i Just need some confirming help!! just a noob!!
    That pump is fine maybe even a little large, but it's 2-speed so it will work fine. That filter is a little smaller than I would recommend but it will work. I see that they don't offer a 200 sqft or larger filter with a pump combo. You may want to call them and see what they can do.
    So for the 40 x 18, should I look for a 1hp with 200sq. ft. cartridge filter system?
    Also, I have read the 2 best options for keeping water clean is household bleach or swg system.
    I was originally looking at an inline chlorinator to keep the water clean.
    But after reading, not so sure.
    Do people actually just use grocery store bleach all summer long to keep their pool clean?
    What is the easiest, most reasonable system to keep my water clean?
    30,431
    BBB, of course.
    But what BBB means is that you understand how to test accurately and interpret your test results so you know how to manage your pool. In other words, there is no ONE chlorination method that is totally perfect and head and shoulders better than anything else.
    The best "system" is you gaining the knowledge to understand what parameters to test for and what to do with your test results.
    Your education begins with Pool School.
    read "The ABC's of Pool Water Chemistry" article first.
    Quote Originally Posted by mayhem69
    Yes http://www.troublefreepool.com/getti...re-t64842.html
    ...and be prepared.
    15,000 gal, IG, Vinyl
    Cartridge Filter: Hayward C12002, 120 GPM
    Pump: 1.5 hp, Flotec AT251501-01
    TF-100 Test Kit
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Just bought 20 bottles of Tandil at Aldi's last night. I'm looking at getting a stenner pump to automate the delivery, but for now I just pour the proper amount in by hand. Here's another link http://www.troublefreepool.com/bleac...13-t58266.html
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    22,553
    I don't use anything except grocery store bleach for chlorination in my pool.
    I have an injection pump and a 15 gallon drum that I fill up about once a month. You should see the looks I get when I buy 16 bottles of bleach at one time.
    Yes, I would recommend a 1 hp 2-speed pump and a 200 sqft filter.
    You fill up a 15 gallon drum once a month with bleach?? huh?? How many gallons is your pool? I wouldn't mind using bleach if it is the best way to keep my pool water clean, but is it cheaper than chlorine? Also, is it safe to open my eyes underwater using bleach? I have just never heard of using bleach to replace chlorine.
    I read in another link on this thread about a liquidator to shoot the chlorine into the system.
    Do you have a link for one of these things? Approx. how much bleach would I use per month for the 20,000 gallon pool? I just don't know I am new at this stuff and want it to be easy.
    As far as a 1HP dual speed pump with 200 ft. cartridge, I cannot find, got a link?
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Bleach is liquid chlorine just different concentration. Look at the labels sometime, the solid chlorine has other stuff that's undesirable, either cya or CH both of which if you have too much can cause problems.
    Dan D
    22,553
    Well first thing you need to know is that bleach IS chlorine! It's the same chlorine that's in all those other pool chlorine sources. Don't be fooled by someone telling you it's different.
    So is it safe? Yes it is! It's as safe or safer than any other pool chemical.
    At 20,000 gallons you're about the top of what I'd recommend the liquidator. For your pool I'd recommend an injection pump and drum.
    You'll probably use about 15 gallons of 8.25% per month.
    so can I just buy this injection pump and drum at a pool online store?? or is this something I have to do custom.
    I did find this dual speed pump here
    http://www.cheappoolproducts.com/Haywar ... oduct.html
    can I use that pump with this filter cartridge system?
    http://www.amazon.com/Jandy-CS200-200-S ... ool+filter
    That is going to cost me a little more than going with the Hayward 1.5hp dual speed and 150 sq. ft. pump I posted above.
    Are you sure I should only go 1hp with a big 40 x 18 x 54" pool?
    22,553
    Most of us just buy the injection pump online and either get the tank the same place or find a standard plastic drum somewhere. I got mine from USwater systems I think. The drum I got off Ebay.
    There's a thread all about my injection system called "I've defected to the dark side".
    The pump and filter you linked to is fine together. That pump is more than enough for that pool.
    yea, but now thinking about it, the jandy filter cartridge above is 2" outlet and the pump is 1 1/2"
    anyway I found this one, I just might go with it
    https://www.hayward-pool.com/prd/Above- ... 0036_A.htm
    22,553
    It will work fine too.
    my wife just talked to her good friend and she states they use a salt water system and absolutely love it!!
    do you recommend? If so what brand or unit?
    I was looking at this SWG unit, what do you think?
    http://www.amazon.com/Goldline-AQ-TROL- ... d+goldline
