Results 1 to 13 of 13
Thread: Pump - how long should it run?
    Jun 2010
    Toronto, ON. Canada
    230
    We just got our pool opened (new vinyl). PB says that pump should be run 24x7. Is that true? Should I not just be running it for a portion of the day?
    Please help me understand how to determine the duration, settings and run time of the pump please.
    Thanks!
    16'x34' Inground Vinyl Pool. 65,500L. Hayward S244T2 24” Sand Filter. Hayward 1hp Super Pump. Raypak PR266 EN 266,000 btu,. AquaRite SWCG. Aqualamp LED 2 w/ remote
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Pump - how long should it run
    You can start with 12 hours a day and monitor it back it down from there.
    Here's the Pool School article: pool-school/pump_run_time
    You're done SLAMing when:
    22,550
    Since you have a VS pump you could theoretically run it at about 1000 rpm 24 hours a day but you probably don't need to.
    BF gave you good advice. That's a good place to start.
    What speed did the PB tell you to run it at?
    Jun 2010
    Toronto, ON. Canada
    230
    Quote Originally Posted by Butterfly
    Thanks!
    Jun 2010
    Toronto, ON. Canada
    230
    PB said I can run it at V1 (1500 rpm) or lower, as long as the demand for the gas heater allows it to kick in.
    Will read through the link BF provided.
    Jun 2010
    Toronto, ON. Canada
    230
    Re: Pump - how long should it run?
    Read through the link and makes good sense.
    A couple of questions please:
    1. What is the best way to direct returns for optimal circulation?
    2. Should I be having both skimmer and main drain suction on always or slect between one or the other?
    3. SWG - should I turn that off when turning off the pump, or will it simply shutoff since there is no flow detected? PB asked me to leave it at Auto with 35% setting and to bump it to 50% if we plan to have a party.
    Thanks again!
    22,550
    1. That's individual to each pool and you'll just have to play with them to get yours aimed correctly.
    2. Optimal would be to have them both on to some extent.
    3. Ideally it should be wired into the pump timer and shut the power off to it when the pump is not running.
    Jun 2010
    Toronto, ON. Canada
    230
    Another question please - when is it best to run the pump if you say you are running it only for 8-12 hrs a day?
    At the cheapest rate if on tiered electricity rates?
    If the rate is std all day - is it better to run during the day or at night? Also, should the pump run when people are swimming or better to have off?
    Thanks!!
    The best thing is to split up the run time into two or three blocks spread around the clock. Everything else is personal preference and electrical rate issues.
    Jun 2010
    Toronto, ON. Canada
    230
    Thank you.
    Jun 2010
    Toronto, ON. Canada
    230
    I have the SWG, Pump, Heater and Light all as seperate plugs. No switches or timers.
    What should I do when I turn off my pump? I have been turning off (unplugging) the heater and SWG.
    When I run the pump, I have been plugging in the pump, heater and SWG.
    Pump is using 240v and others 120v.
    How would I hook up a switch for all 3 and how would I add a timer? All equipment is outdoor.
    forya's Avatar
    Jun 2013
    SE Pa (Bucks County)
    49
    I had an older analog timer that had 220v and 110v outs on it and had 1 220v in. It came from a pool store in the early 90's
    25,000 Gal, Plaster, IG, Auto CL, Waterfall, IntelFlo VS Pump, Dolphin DX6 Robot, TF 100 test kit, Merlin Safety Cover Lots of Trees!, South Eastern Pa
    May 2013
    North East Ohio
    959
    This what I have and LOVE it.
    http://intermatic.com/Products/Pool_...53_Series.aspx
    It can control 3 circuits - you might need to upgrade for 4 if you want to manage all together.
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
