Results 1 to 9 of 9
Thread: How to start up?
    Jun 2012
    Saint Paul, Minnesota
    10
    How to start up?
    We had to replace vinyl liner this year. Pool is filling as I type this. We are just using garden hose. This is only our second summer with the pool and I still feel like I am learning. Once pool is filled, where do I start first? I do have test kit and will test water but then what? Is there a schedule I should follow? Or can someone direct me where to look on this site for some guidelines on how to start up with all new water? Any guidance is greatly appreciated!
    35K In-ground, vinyl liner, cartridge filter
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: How to start up?
    I would start testing all levels to see where everything is. Adjust PH if needed. Get some chlorine in the water. Then get some CYA in there. Remember the CYA will lower PH. if you don't have everything on hand, go get it now. We don't want to mess up a new fill.
    Jeff
    30,424
    Test your new water right now as you are filling and post the results. Are you filling from a well or municipal water?
    Jun 2012
    10
    Using city water. Pool is still filling. Here are my current readings.
    TC =0
    FC=0
    CYA=0
    ph= 7.8
    TA=230
    CH=260
    Now in what order to I address? Thanks!!!
    30,424
    I forgot to ask....how will you chlorinate the pool?
    Jun 2012
    10
    bleach (clorox or other brand)
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Quote Originally Posted by mobrien719
    TC =0
    FC=0
    CYA=0
    ph= 7.8
    TA=230
    CH=260
    Easy..
    Add chlorine to get to 3 http://www.poolcalculator.com/ can help
    Then mess around filling a sock with CYA stabilizer, tying it off and figuring out how to hang it in front of a return or dangle off a floating toy. That ought to take half an hour or so and expand your childrens' vocabularies.
    Then add acid to take pH down to 7.2. You have high TA, so it will climb really fast, especially as soon as people start splashing around in there, aerating it.
    Mess around some more trying to set up a mat or a footbath or whatever and get the kids changed. That's another half hour.
    Now get in. Jump out again because that water's cold!
    You can reverse the bleach and the acid - it doesn't matter much as long as you wait half an hour between additions.
    Jun 2012
    10
    The company that installed the liner also left 5 1 pound bags of shock. Will that add CYA to pool? Can I just dilute it with pool water and pour in front of return jet? Or do I need to get a different stabilizer?
    Richard320's Avatar
    Jan 2010
    19,023
    Read the label. If it's monopersulfate or calcium hypochloriote, no. If it's dichlor or trichlor (the full names are in pool-school/swimming_pool_definitions_abbreviations), yes.
    The way to use that stuff is to enter your pool size in http://www.poolcalculator.com/ then scroll down to Effects of Adding Chemicals and see just how much that stuff will raise CYA, so you don't overdo it.
    Then go back up and see how much you need to add at a time to raise FC to your target. You don't want to dump it all in at once, or FC will get too high, pH will get too low, and your new liner will bleach white.
