Thread: Recommended CYA level?
    Jun 2013
    Mobile AL
    31
    I am just learning about BBB...I am starting to understand the long term effects, but have a question about cya staying high. I live in a High Rain area, therefore, ph is lowered on a regular basis and backwashing water replacement common. I have always been told not to let the cya zero out. Now that I am researching BBB, is there a cya recommended level? We have rain every day this time of year, sometimes twice a day.
    16 x 36 in-ground
    25,900 gallons
    Hayward Sand
    Hayward Northstar 1hp
    Feb 2008
    Denton, TX
    5,061
    Re: Recommended CYA level?
    Welcome to TFP!
    For regular pools, we recommend a CYA of 30 to 50 ppm. For saltwater pools, we recommend a CYA of 60 to 80 ppm.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Quote Originally Posted by skyjenn
    If you have a lot of water replacement, you'd be one of the fortunate few who can use trichlor pucks with careless abandon. Well, almost. Still, play with the pool calculator and see. Crunch some numbers, see what works out cheapest.
