Thread: Cl levels shooting up?
    forya's Avatar
    Jun 2013
    SE Pa (Bucks County)
    49
    Cl 8
    PH 7.4
    TA 100
    CH 240
    CYA 30
    I am using 3in tabs in a chlorinator, and had a party this weekend. I keep the chloranitor at 6 all the time, but today I noticed it seemed a little strong and it tested at 8. The water is clear. We have had a lot of rain, and i did pump to waste yesterday because the pool was above the skimmers. It has been cloudy, so should i turn the chlorinator down since there is less sun consuming the cL?
    25,000 Gal, Plaster, IG, Auto CL, Waterfall, IntelFlo VS Pump, Dolphin DX6 Robot, TF 100 test kit, Merlin Safety Cover Lots of Trees!, South Eastern Pa
    38,463
    Re: Cl levels shooting up?
    the FC is a little high for your CYA, but not excessively so, still way below shock level.
    Are you planning to stop using the tablets soon before your CYA gets too high?
    forya's Avatar
    Jun 2013
    49
    Maybe, I am still working with the pb, he uses the cl tabs on his new builds, when it is finished i am not sure if i will go to swg or not, but the pool is only 4 weeks old.
    Should I just turn down the chlorinator? or is there something else
    38,463
    Sure. turn it down some.
