Results 1 to 8 of 8
Thread: Pool chemistry
    Jun 2012
    SW Pennsylvania
    77
    Pool chemistry
    Hello all! I have finally taken the cover off of the pool for the summer although the deck is still under construction Water look great numbers are: FC 1.5, CC 0, TA 50, Ch 100 Ph 7.5, BR 2 @ 78degrees. My results from calculator are, 75 oz of 10% bleach, 282 oz of baking soda, 596 oz of calcium chloride and 48 oz of stabilizer. The quantities of baking soda calcium chloride seem large based on no real knowledge . Do I really need to address Ch? Any input is very appreciated.
    Melinda
    AG AquaLeader 21x43 Oval 54" deep. Hayward 2speed 2HP pump,Hayward 350,000 BTU NG Heater, Cartridge filter. Since August 2012. TFT 100 test kit
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Pool chemistry
    Your CH is fine, vinyl pools don't need much CH, our guidlines here is 50ppm+ also you don't list your current CYA level so we can't say how much stabilizer you need, and you should probably hold off on adjusting TA until you get everything else in line
    Jun 2012
    SW Pennsylvania
    77
    Re: Pool chemistry
    Cya that tricky devil... I am getting a reading of 2/3 of the way between 30 and 20 on the vial.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Pool chemistry
    Are you testing CYA under the correct lighting conditions? (outdoors, sun to your back)
    Jun 2012
    SW Pennsylvania
    77
    Re: Pool chemistry
    Is my pool safe to swim in right now, as it is?
    Jun 2012
    SW Pennsylvania
    77
    Re: Pool chemistry
    Yes
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Pool chemistry
    Your FC is a little low so you need to bump it up with bleach see pool-school/chlorine_cya_chart_shock
    but otherwise if it is clear you should be good based on those numbers
    Jun 2012
    SW Pennsylvania
    77
    Re: Pool chemistry
    Thank you Isaac-1.
