Results 1 to 16 of 16
Thread: Can Not Keep Chlorine In
    FC 1.3
    CC 0
    PH 7.3
    CYA 75
    CH 245
    Water is clear. Did over night test 4.5 next morning 2.0. How can water be so clear but you have something growing in it?
    IG: 11' x 26' Fiberglass (6,700 Gallons), Hayward 1 HP 2 Speed Pump, Hayward Sand Filter, P4 Aqua Logic Controller, T-15 Salt Cell. TF-100 Test Kit
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Can Not Keep Chlorine In
    Something may be hidden (under steps, etc.) or just trying to get started. FC is way too low for your CYA level , see pool school link in upper right for CYA/FC chart
    Looks like I need to get my FC up to 5. Do I need to do the shock process? Been trying to keep FC on the low side. When I bring it up I have metal staining to come back>
    Isaac-1's Avatar
    SW Louisiana
    6,711
    yes the shock process would be in order any time you fail an OCLT (over night chlorine loss test)
    38,463
    Add more sequestrant if you need to raise the FC higher ... as you do since you failed the OCLT and now need to follow the Shocking Your Pool PROCESS
    Will get bleach tomorrow. Only going to take about 4 gallons. I have a bag of shock not going to use because of CYA.
    Started shock process this morning.
    FC = 3.5
    CYA 75
    Target FC 28 / 30.
    6700 gal.
    I added 2 gallons of bleach will check with in a hour.
    I concern about my iron staining coming back.
    I added about 4 oz of Seq.
    We are expecting rain today will that cause any problems?
    Butterfly's Avatar
    South Carolina
    10,045
    No, just keep at the shock process.
    You're done SLAMing when:
    1 hour later using 5 ml sample 30 drops. Going to SWG on to help keep it their.
    How long do I maintain this.
    Water has always been clear & CC has been .5 or less.
    Only resin doing shocking process is over night loss. Lost 2.5 / 3.0 over night.
    30,431
    The process is complete when.....
    1. Your pool water is sparkling
    2. Your CC's are .5ppm or less
    3. You can hold your FC overnight without losing more than 1ppm.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Quote Originally Posted by Rambo
    As long as it takes. You might have nipped it in the bud, and one day could have cleared things. But don't neglect to brush. Algae on the walls can form a scab-like covering that protects it from chlorine, so you need to brush it off and expose the guts.
    Remember to turn off the SWG when you try the overnight test again.
    PH went way up off scale. Is this normal??
    Richard320's Avatar
    Jan 2010
    19,051
    Yes. It is well established; Taylor even mentions it on their website. Your pH is not messed up - the test reagent is.
    Check out the pictures: accurate-ph-test-during-shock-levels-with-r-007-t61076.html
    10:45
    CC= 31
    I cut the SWG off at 9:45
    Butterfly's Avatar
    South Carolina
    10,045
    10:45
    CC= 31
    Typo?
    FC 31
