Thread: How much CYA in pucks
    Rockcrawler's Avatar
    El Paso, Texas
    174
    I was reading on here the other day and Chemgeek had posted a post telling how much CYA and clorine was in a 6,7,and 8 oz Puck of Trichlor, but can't find it now I need to raise my CYA from 30 to 70 (SWG install) for a 13000 gal IG, and I have a bucket of Trichlor tablets in the garage, need to know how many pucks to throw in the skimmer
    Thanks
    13,000 IG Plaster, 2hp whisperflo pump, 48 sq in pentair DE Filter, 1 skimmer, 2 eyeball outlets, 200 sq ft solar panels on second story, Auto Pilot SWG-36, Polaris ATV Cleaner
    It takes 125 oz of trichlor to raise CYA by 40 in 13,000 gallons. Don't add it all at once, as it will also raise FC by 66 and lower the PH dramatically.
    You can use my Pool Calculator to figure out things like this. Play with the Effects of adding chemicals section towards the bottom.
    El Paso, Texas
    174
    Thanks Jason,
    Never even noticed the drop down menu for all the different chems, thanks
