Thread: How do I use pool pump to drain
    Jun 2013
    Fortson Georgia
    51
    Split by moderator from HERE. Please start a new topic for your own questions. Thanks, jblizzle
    I wanted to know this as well..so I connect my vacuum hose over the closest skimmer to the pump, close the second skimmer & let the water go to waste?
    Starla
    1993 22x42(40K gal) vinyl Grecian, inground
    Aquarite SWG, Hayward s244t sand filter & 1hp Hayward pump, polaris 380 w/booster pump and dedicated return.
    2 skimmer baskets, main drain, 3 returns along wall, 2 at steps
    Taylor K-2006
    Jun 2013
    Fortson Georgia
    51
    Re: Can I drain pool using pump?
    Also, if anyone can please tell me how much water I need to drain? I have a 40k pool with SWG. My CYA is 100, I'm aiming for CYA of 80.
    Thanks SOO much!!
    Starla
    Taylor K-2006
    22,553
    Re: How do I use pool pump to drain
    It's a direct ratio. If it really is 100 ppm then you need to drain 20% of the water to get to 80 ppm. I'd go a little more than that just to be safe.
    So about 8,000 gallons. Or if your average pool depth is about 5 feet, you'd need to drain about 1 foot.
    38,539
    Welcome to TFP!!!
    How sure are you about the 100ppm CYA reading? How did you test it?
    Realize that most good tests max out at 100ppm and you could be well above that.
