Results 1 to 8 of 8
Thread: pool 6-8 in down for skimmer install, filled up, CYA test?
    Jun 2013
    Newcastle, Oklahoma
    508
    got through wall skimmer installed, how long should i wait to test my CYA level after raising level back up?
    Partially buried Doughboy Desert Spring 16 x 32, sport pool, with 7 ft deep middle, 20,000 gallons, Hayward Powerflo Matrix 1.5 HP 2 speed pump, 250 lb sandfilter, 2 Doughboy skimmers and 2 returns. 2 cascade fountains.
    Taylor K-2006 kit. Zodiac Barracuda Ranger suction side cleaner.
    TFPC method and is crystal clear every day thanks to TFP!!!
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Re: pool 6-8 in down for skimmer install, filled up, CYA te
    Did you add any stabilizer? Was it granular? If so, wait a week. If not, measure it now.
    Edit to add: Even if you did add granular, you can still measure your CYA now. But the extra that you added won't show up for perhaps a week. If you know how much you added you can calculate how much it will raise your CYA.
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    Jun 2013
    Newcastle, Oklahoma
    508
    no, i didnt add any. my CYA was a little high before i let level drop for skimmer. (80) im sure its down a bit now after i filled it back up. i just want to do another CYA test so i can dial in my chlorine for the new CYA level. i was thinking wait a day....
    Jul 2011
    844
    No need to wait. The CYA is dissolved long ago. It's mixed in with the added water. You say it was 80. You dropped 6 inches in a 4 foot pool. That's 1/8th (based on 4 foot water level which you're probably a little less than). My guess is your CYA is 70 (if it was indeed 80). Let me know what your test shows as that's just a guess!!
    Bestway SWG
    Jun 2013
    Newcastle, Oklahoma
    508
    hmm... still 80. oh, well. its only costing me 40-45 oz of chlorine a day, plus direct sun on this pool from sun up to sun down so it needs a higher CYA. pool crystal clear as always. TA a little high at 120, was 100 before this, its a vinyl pool though so im not too worried about it. pH is 7.8, but we have been running fountain a lot to cool pool so thats expected, that may be why TA is a little high too.
    Casey's Avatar
    SW PA
    10,457
    You need to get that pH down to 7.2 if you're running the fountains.
    Jul 2011
    844
    Also + or -10 on CYA is not abnormal. you could have been at 85 down to 75. Or even 90, now 80, or 80 now 70. Either of those could give you a reading of 80.
    Bestway SWG
    Jun 2013
    Newcastle, Oklahoma
    508
    Quote Originally Posted by Casey
    yeah, its been hovering right at 7.4 up until now when i topped it back off. i only test it every other day as it doesnt change much. ive read on here in various conversations that on a vinyl pool higher pH isnt such a bad thing. some members were even saying 7.9-8.0 for a vinyl pool isnt cause for alarm, so i havent been too worried about it.
    im gonna give it a few days to see if it goes down on its own. its cooler now this week and pool is staying in low 80s so no need to run fountain, so we havent been. if it doesnt start working its way down or goes up any more ill take action on it. pH was high like that after my initial fill, so im thinking our city water just has a high pH.
