Thread: Return Line Eyelids, Yeah I have no idea please help
    Jun 2008
    Maryland
    13
    Ok,
    I live in a wooded neighborhood and we often have bees and wasps stopping by the pool for a cocktail and appetizers.
    My neighbor suggested placing directional covers, eyelids to have the returning water brake the surface so it is not smooth for the visitors.
    My return lines have a threaded pvc part inside the wall, rather flush to the wall that I could screw these parts into.
    So can you name this part, where I could get these, I think its 2 inch piping, and has anyone tried this
    55,000 In Ground Gunite
    Pentair CC Cartridge Filter 420 Sq Ft
    Polaris 360
    Skimlite Dually Pole and nets (highly recommend)
    No SWG-Yet
    No BBB-Yet
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Eyeballs is the term you are looking for. Any pool store should have them.
    Mar 2007
    Coastalish 'down easter'
    4,160
    They are also known as 'directional inlets' - but everyone calls them 'eyeballs'
    Luv& Luk
    -Ted
    Butterfly's Avatar
    South Carolina
    10,045
    You may want to keep a closer watch on your TA and pH after you turn the eyeballs to break the surface of the water.
    Over time, this will cause your TA to drop and your pH to rise.
    You're done SLAMing when:
    Apr 2008
    Central Texas
    326
    Do you have borates in your pool? I used to have a problem with wasps, but once I added borax the borates seemed to break the surface tension of the water so that wasps sink and drown. That cut down on the problem considerably.
    26,000 Gallon Gunnite IGP
    2 HP Challenger High Head Pump
    60sf Nautilus DE filter
    Polaris 280
