Thread: Lowering TA. PH tough to get back up.
    prosper's Avatar
    Jan 2013
    Taxachusetts
    57
    New pool here. Water brought in with tanker trucks.
    TA a bit high at 140.
    I've got a SWG, but have not installed it yet.
    Anywho....
    I'm going to get TA down to 80 and started the process yesterday.
    Pre-start numbers:
    TC 3
    PH 7.6
    CYA 50
    CH 70
    TA 140
    Monday 3:30PM - PH 7.6 -- TA 140
    Monday 3:45PM - Added 1 Gallon of 31.45% MA and start aerating with 3 headed homemade return fountain like others on this site use.
    Monday 4:30PM - PH 7.0 -- TA 120
    Monday 9:40PM - PH 7.2 -- TA 120
    Tuesday 9:30AM - PH 7.2 -- TA 110
    Pump is running 24x7 during this process. Aerator is also attached and running entire time.
    So, to me, everything was going as planned until the Tuesday morning test.
    I was expecting to see PH 7.6ish and TA 120.
    Odd eh?
    35k gallon 20x45 inground concrete with vinyl liner - Stamped Concrete deck
    Pentair WhisperFlo 2HP - Pentair FNS Plus 60 DE
    Heat Siphon heat pump - Compupool cpx48
    Blue Diamond RC robot vacuum - TF100 testkit
    Re: Lowering TA. PH tough to get back up.
    Lowering TA can take quite a while. Minor fluctuations in your test results are to be expected along the way.
    Aug 2010
    Dallas, TX
    4,052
    Once you start that SWG I'm betting your pH starts swinging up without issue.
    prosper's Avatar
    Jan 2013
    Taxachusetts
    57
    Took a little longer than I expected for PH to rise with aeration, but all is well now.
    Will just repeat process until TA is where I want it.
    Tuesday 10:00PM - PH 7.6 -- TA 110
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Have a pool party. A lot of splash fights and cannonballs and children flailing around trying to swim will aerate things nicely.
