Thread: After shock...what next?
    Aug 2011
    Northville, Mi
    314
    Well, I finally obliterated whatever was growing (water was never even cloudy) but now I have a CYA level of around 40-50, a pH around 7.2 and FC of about 25. I'd like to try and get the FC down to at least close to target before bumping up CYA. And I'm not even sure at what level FC I can even try and figure out what my pH is currently.
    So, some questions I'm hoping you gentle folk can answer for me...
    1. At what FC level can you get a reliable pH reading? I know it's too high now, but how low FC is low enough?
    2. Given I have some CYA in the pool, I don't expect the quick burn off of FC (when we actually get some sun here!). I'll be waiting a while if I want the sun to burn it off, won't I?
    3. I seem to recall if FC is below shock level, you can swim. Is that a good rule of thumb? Or is there a hard number as well that you want to avoid?
    4. I recall reading that you can also use something to lower chlorine. Anyone remember what it is and what else it might affect?
    5. I'm assuming pH needs to be 7.4 or so to swim. If I turned on the deck jets and turned the returns so they shot in the air, any kind of rough idea how fast the pH would raise at around 100TA?
    6. Lastly, there's some junk in the pool that needs to be cleaned. I'd like to throw my dolphin M4 in and let it go to work. But the manual says 4ppm max of Chlorine. Any idea what high chlorine levels would do to it?
    And thanks in advance everyone. This really is an awesome place. I shudder to think where I'd be if there was no TFP and I had to rely on the pool store!
    15,400 gal, 16x32 vinyl rectangle (sport dig), Intelliflo VS, 240 sqft cartridge filter, Intellichlor IC40, Mastertemp 250, Dolphin supreme M4 cleaning, Pentair EasyTouch4, Tested regularly and accurately with supplies from tftestkits
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Re: After shock...what next?
    Quote Originally Posted by doncaruana
    1. At what FC level can you get a reliable pH reading? I know it's too high now, but how low FC is low enough? 10
    2. Given I have some CYA in the pool, I don't expect the quick burn off of FC (when we actually get some sun here!). I'll be waiting a while if I want the sun to burn it off, won't I? Yes.
    3. I seem to recall if FC is below shock level, you can swim. Is that a good rule of thumb? Or is there a hard number as well that you want to avoid? It's safe to swim. When I had astronomical CYA, we swam in 22 FC every day
    4. I recall reading that you can also use something to lower chlorine. Anyone remember what it is and what else it might affect? Many things will lower FC - peroxide, thiosulfite, ammonia...it'll drift down without spending any money
    5. I'm assuming pH needs to be 7.4 or so to swim. If I turned on the deck jets and turned the returns so they shot in the air, any kind of rough idea how fast the pH would raise at around 100TA? You don't really know pH with FC so high
    6. Lastly, there's some junk in the pool that needs to be cleaned. I'd like to throw my dolphin M4 in and let it go to work. But the manual says 4ppm max of Chlorine. Any idea what high chlorine levels would do to it? They're assuming the worst - 4 PPM in a fresh fill with no CYA. At shock level for your CYA, you actually have less aggressive FC. I wouldn't hesitate to put it in for a couple hours to let it do its thing.
    You would have no green in your wallet and lots in your pool
    Aug 2011
    Northville, Mi
    314
    Quote Originally Posted by Richard320
    I lowered it to 7.2 or 7.1 (color matching not my thing) before I started the shocking a few days ago. Would anything normally raise it? At that low of a level, is it safe to swim?
    *That* was literally laugh-out-loud funny!
    Thanks again!
    Smykowski's Avatar
    Sep 2011
    3,065
    Low pH is more damaging to equipment than swimmers. At worst, you might get a little eye irritation. Go swimming!
