Results 1 to 7 of 7
Thread: fixing liner pulled away from coping
    So I bought a house with a neglected liner that was filthy. I actually got it to look quite respectable and set it into the coping. I started to fill up the pool. I now have two spots where I have a pronounced U shape where the liner was pulled down and out of the coping and there is no wag its going to be pulled up. I tried waiting for a hot day and using both hot water from stove and a hair dryer. I think the liberty may have just lost some elasticity. What I'm looking for are some make shift ideas on how to get around this issue so o can fill the water up to the Skimmer with out it leaking behind my liner. Right now I have a section of pool hose in the Skimmer and submerged so I can filter the water. I think using a liner repair glue and an old cut piece of liner would work but no idea where to get one. The patches sold in repaid kits are two small (I need like two 1.5 foot x 1 foot patches). I was also thinking of putting some ice and water shield on the u shapes. The stuff is really sticky and is meant to repel water off roofs. Let me know all of your ideas. Thanks in advance.
    22,542
    Re: fixing liner pulled away from coping
    If you could find and installer they might have a piece of liner that's big enough, but I'm not sure it's going to work. It's probably worth a try though.
    Do the installers usually have scrap pieces?
    22,542
    Above ground installers will usually have some left from overlap installs. There's always some left from skimmer installs but they're not large enough for you.
    OK I'll check around. Thanks for the info
    Casey's Avatar
    SW PA
    10,423
    Have any pics you can show us?
    topher's Avatar
    Jun 2012
    toronto, Ontario, Canada
    136
    I got a cutoff piece from the pool store that was about 12 inch by 4ft long for a tear that I had caused by a sheet of plywood
    13500 gallon AG, build late 90's, Hayward S220T sand filter,1Hp aqua coastal
    Gasser BBQ broilmate 155154 LP, Smoker CGK (akorn)
