Thread: How to balance - Pump run time for SWG and HeatPump
    I would like to being to use my heatpump to maintain a temp in my pool. I currently only use my gas heater to lift temp to desired when needed. My challenge on the heatpump has been that for me to get a good chlorine level in my pool, i can only run my 2 speed pump on low for 10 hours @ 30% generating levels for salt cell. Doing any more and my levels get to high. So if a heat pump takes time to maintain temp and with my pump run rate only 10 hours, won't this have my heat pump cycles running longer due to being off all night/morning? Is that more or less efficient? (Yes I cover my pool every night with solar cover). Hayward Pro Logic uses the pump time as the primary ruling condition, not if the pool temp is low. So even if the temp drops below what the heat pump is set, it doesn't sense that and will not react until the timer turns on the pump to low, to then be forced to high due to call for heat.
    Thoughts?
    Thanks!
    Ted
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Re: How to balance - Pump run time for SWG and HeatPump
    getting-swg-to-run-the-same-amount-regardless-of-pumpruntime-t58358.html
    In that thread you'll find some ideas to eliminate part of your issue, SWG run time %.
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
