Thread: Amount of CYA in a 3" chlorine tab
    Jul 2011
    North East
    135
    How much CYA is in a 3" chlorine tab?
    Recently came across some and would like to use them up, but want to know the numbers
    25,000 gallon Concrete/Plaster Pool
    Pentair WFDS-26 - Installed Spring 2012
    Pentair Quad DE 100 - Installed Spring 2012
    Pentair Kreepy Krauly 820 - In Service 05/26/2013
    K-2006 Test kit, Intermatic P1353me Digital Timer, Stenner 85MHP5
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Re: Amount of CYA in a 3" chlorine tab
    For your pool. each 8 oz trichlor puck will raise FC 2.2 raise CYA 1.3 lower pH by .12
    Jul 2011
    North East
    135
    Thank you!
