Thread: New owner in Texas
    New owner in Texas
    Just bought a new home in Katy/Houston Texas, trying to learn about the new hobby. Been to Pool School - printed a book about it.
    So I inherited a Salt Water Generator, Jandy AquaLink. The water is blue, not too untidy on the bottom of the pool, pretty clear but not crystal, and temp around 85 to 91 degrees.
    Polaris 280 not working, permanent squirt of jet (that moves it from corners) bearings sound clunky. Unplugged now.
    Pump filter looks like it has air going through it and no water - does this have anything to do with the Polaris booster pump?
    Test Results:
    26th June:
    pH = > 8.2
    FC = 2ppm
    CC = 0.5ppm
    TA = 40
    CH > 200 not confirmed as solution still pink
    Salt cell reading 3000ppm, strip test 2200ppm
    CYA ~ 0
    So I added 48 fluid oz of 8.25% bleach and 14 oz of Muriatic acid.
    1st June:
    pH = ~ 8
    FC = 1ppm
    CC = 1ppm
    TA = 40
    CH - test was always purple, not blue
    Salt cell reading 3300ppm, strip test 2800ppm
    So the pH is a bit better, but the FC level is worse.
    Plan of action is to add CYA, but looks like I need around the whole container - 4lbs, and then hit away at the bleach and the Muraitic acid. Does that sound sensible?
    I'd like to understand how the system works - i.e. whether the salt reading is correct or not and whether I should be trying to get the FC level higher with Bleach or running the SWG for longer and adding some salt - if needed.
    Any advise appreciated
    Pool size ~ 14000 gallons, in-ground plaster, Jandy AqualinkRS salt water generator, cartridge filter, Pump TBC - in Houston Texas
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: New owner in Texas
    Welcome to tfp, Nico24
    You CC>0.5 and the not crystal clear water tells us you need to do the shocking process. See: http://www.troublefreepool.com/pool-...king_your_pool
    Before starting that, I would lower the ph down to 7.4 or so. Dose with Muriatic Acid, then test again in an hour and redose until you reach a ph of 7.4.
    I would also start getting 20 ppm of cya into the pool by filling an old sock and hanging it in front the the pool return (water coming back to the pool).
    I would do the shocking process with the saltwater chlorine generator (swg) off.
    The air in you pump basket is likely a suction side issue/leak. Check the pool water level, look for a stuck skimmer, and relube the pump basket gasket.
    Thanks Linen - that's given me the pointers I need to get going. Lucky I'm on vacation to give it a go.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by Nico24
    Good deal...you'll have something to keep you from missing work so much. Have at it and let us know how it goes, but you'll do fine with your willingness to learn this stuff. It isn't complicated at all.
    Welcome to TFP and enjoy the forum.
    Essential Links:
